LibreCAD commands
joe
LibreCAD commands
joe
Hello everybody,
According to this post, LibreCAD can be controlled by commands. This is a great feature, since it is possible to create drawings programmatically.
However, I don't seem to find any commands to create and select layers. Am I missing something obvious?
While at it: is there a possibility to read the drawing commands from a file?
Re: LibreCAD commands
sp1der
The commands being referred to are only basic short cut typed in codes at the command line for simple tool use. Nothing so spectacular as a command for select/create layers is available..yet -anyway!
See here for a list of short cut key codes for LibreCAD:
http://wiki.librecad.org/index.php/A_short_manual_for_use_from_the_command_line
joe
joe
Too bad...
And it's not even possible to fill in commands via cut-n-paste. If I type something like
"li 0,0 10,10"
it will be ignored. It won't even work if I paste something like
li
0,0
10,10
Am I missing something? Do I really have to type everything manually? What's the point of the command interface, then?
sp1der
I hear you Joe, it does seem pointless...but there you go - it is what it is for now.
But hey Joe at least libreCAD is free, cant complain!
Maybe you can add a feature request for something to be developed:
http://sourceforge.net/p/librecad/feature-requests/
