On 15/09/2011 11:39, Rallaz wrote: > > 2011/9/15 Claude Sylvain<csylvain@electro-technica.com>: >> >> Hello Rallaz, >> >> - After taking a look at your ".lff" fonts, I think I will begin >> to test the "romans2.lff" font, since this font looks like >> the "ic-simplex.shx" font of IntelliCAD. >> The only noticeable difference is that "romans2.lff" is little bit >> smaller than "ic-simplex.shx". >> >> - Maybe we can create a modified version of that font >> ("romans2.lff") by doing the following modifications: >> >> - Create the new font using "romans2.lff", and name >> it as "simplex.lff" >> > No problem (or "simplex-1.lff") > - So, Ok for "simplex-1.lff". > >> - Find a way to scale up "simplex.lff" such a way that >> its dimension is the same as "ic-simplex.shx" >> (found in IntelliCAD). >> > for now I will apply a temporary change to the code of the exporter to > apply a scale all the coordinates and see what happens > - I just tested "romans2-scaled.lff, and its scale is just perfect! i.e.: Have the same size has IntelliCAD "ic-simplex.shx". - Good job Rallaz. - I updated the "simplex-1.lff" I created with this font. > >> - Add characters that include accent. >> > This is simple reusing letters definition > - Good. - Will you take care of that modification or do you prefer that I do it ? > >> - Also, this font is not copyrighted by Andrew Mustun, but by >> Adam Radlowski. > > Adam Radlowski have only the last 14 chars (polish) "latin extended > A" from 0104 to 00f3 > these chars are letters in public domain + accent or similar. > tip: if you use KDE kcharselect is very useful. > - So, they will not have copyright problem with that font. Good. > > I think I sent you some files that are poorly converted. > if you open romans2.cxf with master and then "select all" show: > selected entities: 228 (114 blocks& 114 texts) > the romans2.cxf I sent have another quantity, resend you this file. > Ok. > >> - Remark: If you prefer that I send you emails using >> LibreCAD forum, let me know. > > is fine as well > - Ok. Will use LibreCAD mailing list / Forum. - Attached, the "simplex-1.lff" font. Claude simplex-1.lff.zip |
simplex does not exist in librecad so is changed:
if (style == "simplex") then style = "normallatin2"; when the font is finished then rename to simplex.lff and change the code. considerations: The field "Format" should be version for possible formats redesigns like v12, v2000, v2007 in dwg The field "Author" is also handled by LibreCAD and require a line starting by "# Author:" to handle it and not lose any author when the file is saved. Fields "Created:", "Last modified:" and "Notes" are treated as commentaries If you open the font with LibreCAD, then saved, are lost. I have to watch that when the file is saved do not miss the comments and update # Last modified: > - Will you take care of that modification or do you > prefer that I do it ? I now I have little time and hard work if you take care I would be happy :-) And if you do, feel free to ask Rallaz |
Claude:
I have written a converter from jhf (Hershey fonts) to lff Is a qt4 console, you can get it: http://sourceforge.net/projects/rallaz.u/files/fontconverter/fontconverter.zip/download I converted the file romans.jhf (in QCAD romans2.cxf) to romans.lff and added more chars, the same ones that were added by Adam Radlowski and the five vowels in capital and small, with open and closed accent. This file is a good example in how to reuse chars definitions. romans.lff something else, what is your opinion regarding change already .cxf files for .lff? Who are interested: the above link have all Hershey fonts converted to .lff if someone else is encouraged to add characters also have the font ISO-3098 in dwg and svg (in QCAD called normal, normallatin1, normallatin2 and standard) |
Hello Rallaz, On 23/09/2011 13:59, Rallaz [via LibreCAD] wrote: > > I have written a converter from jhf (Hershey fonts) to lff > Is a qt4 console, you can get it: > http://sourceforge.net/projects/rallaz.u/files/fontconverter/fontconverter.zip/download > Great! This will enhance LibreCAD fonts a lot :-) > > I converted the file romans.jhf (in QCAD romans2.cxf) to romans.lff and > added more chars, the same ones that were added by Adam Radlowski and > the five vowels in capital and small, with open and closed accent. > > This file is a good example in how to reuse chars definitions. > romans.lff <http://librecad.1049103.n5.nabble.com/file/n4834550/romans.lff> > - Interresting. So now, we can forget "romans2.cxf" and "romans2.lff", and use "romans.lff". - Wondering if I can use your "romans.lff" as replacement for "simplex(-1).lff". I will take a look at that. - By the way, I had no time to add accents on "simplex(-1).lff" :-( > > something else, what is your opinion regarding change already .cxf files > for .lff? > - After doing some functional tests on all ".lff" fonts I was aware of, I think the ".lff" font format is mostly usable. Claude |
In reply to this post by ClaudeQC
Good day! I tried LibreCAD and i liked it, but didn't find the font we use in our country as standard (Ghost Type A). Searching in the internet found a free version of ttf fonts i need (opengostfont-ttf-0.3). Could You convert them to lff and send me on e-mail (chymax3m@mail.ru). Hope to see these fonts included to new versions of LibreCAD. Good luck!
there's a ttf2lff tool comes with LibreCAD.
You can generate the lff fonts using ttf2lff. If you the ttf fonts are licensed by free software terms, we may include the lff fonts in LibreCAD.
I've uploaded an archive with fonts and license i've been writing about. Please include it into a new release. Regards, Vladymyr
http://rghost.ru/41281459 P.S. I'm using Windows 7 SP1 x64, and couldn't find the ttf2lff tool for windows OS. Could You convert those font files and send it to my e-mail: chymax3m@mail.ru. Would be greatfull. |
Thanks!
I will add it to both 2.0 and 1.0 series. as 2.0.0beta1 already tagged, it should appear in 2.0.0beta2 release. dxli |
Would You be so kind to send me the converted fonts?
Thanks, i'd already written to dxli on e-mail about my trouble, but there were no answer. Those fonts are Cyrullic-type (Russian), but when i imported them in LibreCAD 2 beta 1 they reflected as some ASCII symbols, not letters. Is this the trouble of a new version of LibreCAD, or in me? And one more thing, sorry for offtop, the button "Grid" in main pannel doesn't create grid.
Regards, Vladymyr. |
