If so, I will review the circle trimming first on angles.
If needed, I will probably create new entity API for trimming. The current trimming API separates the information of trimming input, making trimming implementation complex at geometry level.
Some details:
We should handle trimming at geometry level with the following information:
1, the closest point on entity to the mouse pointer, when clicking to trim;
2, the intersection points to the limiting entity.
Currently, the API first takens info 1, then, create a new trim point concept, and trimming based on that trimming point.
Consider trimming a full ellipse with another, the complexity is clear.
sand1024 wrote
Trim behavior for circle is definitely a bug, depending on selection point on circle trim points are defined incorrectly.
Could you please report issue on GitLab (one for trim and one for lengthen)?
The link is here -
https://github.com/LibreCAD/LibreCAD/issues
