Lines went to infinity.
18 messages Options
squirp
On layer Windows all the lines went to infinity, while doing a line parallel to operation on a half inch line. I have the file attached. I tried a refresh and a restart of the application but no improvement. The file is below.
2259-DevonPlace-Kitchen.dxf
Do you see the same thing?
Re: Lines went to infinity.
squirp
The version might prove useful!
Version: master
SCM Revision: 2.0.0alpha4
Compiled on: Sep 11 2012
Hope this helps.
In reply to this post by squirp
squirp
I don't see a help layer. The layer list and the Layer menu doesn't
mention it. Am I missing something?
On 09/14/2012 01:49 PM, R. van Twisk [via LibreCAD] wrote:
> Check in your layers if the 'help layer' is checked.
Screenshot from Librecad.png (237K) Download Attachment
squirp
AHHH! Found the "help layer" - it was checked and unchecking seemed to fix it - Thanks!
If you have time, could you tell me what the purpose of "help layer" is? I must of clicked it by accident.
Paul
Best regards R. van Twisk
Tel. +1 803 426 3350    Skype: r.vantwisk     gtalk:[hidden email]
http://forum.librecad.org/Lines-went-to-infinity-tp5707037.html
http://forum.librecad.org/Lines-went-to-infinity-tp5707037p5707039.html
To unsubscribe from Lines went to infinity., click here.
Lucas
Same here.
All layers are now marked as "help lines". No matter if I uncheck them and save, next time they'll be "help lines" again.
Any thought?
Version: master
Compiled on: Nov 26 2012
OS: Ubuntu 12.10.
Lucas
Ries,
I've been doing some tests. This behvior desn't happen when you save the file in autocad R12 format.
Also, I've tested the same with it with the windows version (2.0.0beta1) with the same results.
Let me try it again in Ubuntu, but with the beta version.
Thanks!
Lucas
ePoxi
Ok,
On Ubuntu 12.10 now. Updated LibreCAD to (via ppa):
Version: master
SCM Revision: 2.0.0beta1
Compiled on: Dec 3 2012
(Version: 2.0.0~beta1+yeslib20121201+264864a-0ubuntu0~daily7~quantal1)
The problem persists.
* Create a new file and Draw something (not using layer 0).
* Create second layer as Help Layer"
* Draw a fwe lines.
* Save as... (default DXF 2007)
* Close
* Open it again
Except Layer 0, the rest are marked as "help layer/s".
Hi Lucas:
In LC new drawing
create layer L1 and draw a line in it
create layer L2 with "help layer" marked and draw a line in it
Save as...  helptest.dxf (in default DXF 2007)
close helptest.dxf and reopen it
Result: layer 0 & L1 are normal layers and L2 are help layer
Tested in winXP-32b, openSuse-64b & LUbuntu-64b 12.10
that is, work as expected in all tested systems using the last code (Dec 1 2012 )
You can do all the steps and attach the created file?
Ok, Lucas
I think I know what the problem is.
If you open a drawing and only changes the state of the layers, for LC, you did not change the drawing
then click in "File->save" nothing happen
verification: open the file, then cilck in "close" no warning are sown.
Workaround:  changes the state of the layers, draw a line, delete it, then close
ePoxi
First of all thanks for your support!!!
I just did what you mentioned.
* Opened a .DXF 2007 file, with all "help layers".
* Corrected the layers that are not supposed to be "help" ones.
* Draw a line.
* Save (with the icon on the toolbar).
* Delete the line.
* Save & Close.
* Open de same file again. All layers are "help layers" except layer 0.
I really don't know what I doing wrong now :(
If the file is corrupt, it showld be restored as I change the layers properties, right?
EDIT: As an example this is one of the files I'm working with --> http://depositfiles.com/files/dvgli7mw1
Tests made with winXP-32b, openSuse-64b & LUbuntu-64b 12.10 using Gear-Small.dxf and same result in all
When Opened with LC all layers are "help layer" except 0
Changed all to NO "help layer"
Draw a line then press ESC to finish command line
Click in undo button to remove line
"File->save as..." saved as Gear-SmallRLZ.dxf
Close LC, reopen LC and Gear-SmallRLZ.dxf
result: all layers are normal layers NO "help layer"
I can not reproduce your problem :-(
Gear-SmallRLZ.dxf.zip
ePoxi
Hi Rallaz,
Thanks for your time!
Followed your steps, now saving changes with the "save as..." instead just the save button.
Same situation.
I've recorded my desktop showing all the process: http://www.youtube.com/watch?v=Ew26dPGC9NM
Maybe is a problem with my system.
I watched the video and you do not make the same steps as me.
I put ALL layers printables (no help layer) and you all except "Gear-Small-Aux"
This is the difference that has allowed me to find the bug
A patch is sent, only wait for a new daily-build (amd64 are queued, i386 ready).
Tip: to change the layer "print state" simply clic in printer icon
ePoxi
Thanks Rallaz!!!
I'll wait for the daily build :D
ePoxi
Hi Rallaz,
It's working now!!!
Thanks for patching it :D
Regads.-
Lucas
