Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hello everyone,
I am new to Libre CAD and my question is this, I managed to create a custom logo text and when I export the DXF to SVG and open it with Inkscape the letters are scattered and some of them are not even inside the layer, is there a solution? thanks for your help |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Without a look on the file not much can be said. You can provide the file here with -More v- -Upload a file-.
What is your intention? Why export to SVG? Export to SVG in LibreCAD is more intended for CAD/CAM purposes. For graphical use better export to PDF and open that in Inkscape. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
The problem would have been easier to understand with a screenshot of the input and output. It's pretty clear it is a bug with LO export to svg.
For a logo you want high quality. I suspect all the data is there but some of the X coordinates are wrong. It might be better to just edit them in the svg file. Using https://cloudconvert.com/dxf-to-svg atoss.svg it seems you would want to clip the output too: ![]() |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
In reply to this post by mineralman
It seems it has something to do with the use of blocks. If you explode the the whole drawing before exporting to svg it turns out right. You also can open the dxf directly in Inkscape, turns out right.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Block features are too buggy, some help needed.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This issue appears to be limited to the SVG generator though.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on Apr 01, 2024; 8:13pm.
I pushed a fix for blocks in SVG:
https://github.com/LibreCAD/LibreCAD/commit/56b3cfb59e4b152bd2ce7874793ad74639ed9eb3 it works for me so far with atoss.dxf As the block feature of LibreCAD is not satisfying, it may help to explode block instances to workaround block bugs. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Impressive! well done dxli, I'm glad if my problem helped to fix bugs in LibreCAD, I didn't know that Inkscape handles DXF files, and it works fine, it's the result I expected except the points of constraints, I don't know how to get rid of them? |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I finally managed to remove the constraint point the result is perfect and clean, Thanks all for your help |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Great.
I also added an option to control point exporting. In addition, you may also use LibreCAD as a command line conversion tool to convert dxf to svg. To generate foo.svg from foo.dxf: librecad dxf2svg foo.dxf
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I apreciate it dxli, i hope the best for you
