New user
10 messages Options
New user
Kevin Brown
Hello   LibreCAD users,   I have been trying to get to the basics of LibreCAD but find that the dimensions to the shapes that that draw are not visible, there is a box where the dimensions should be but no dimensions..     I say that but when i first had a look at this the dimensions were there.  A fundamental blocker for me ?    Any suggestions ?
Re: New user
sand1024
check whether draft mode is enabled or not. In draft mode, texts are no drawn (only box around the text is visible)
Re: New user
In reply to this post by Kevin Brown
Switch off View - "Draft" mode. It simplifies text to boxes to speed up screen rendering.
Re: New user
Kevin Brown
Thank you .  Sand 1024      My problem appears to be similar to this post with an association to the pan/zoom, that i have found in the forum.
"When doing dimensions I only get a box above the dim line.
I have read many posts on this forum on this issue.  However, none of the fixes work.
I recently downloaded LibreCAD.  I am using  version 2.2.0.2
I am NOT in Draft mode!
I saved my drawing then closed the program.  I reopened the program and my drawing.
The dimensions were magically shown above the dim lines.
I can Zoom In/Out/Previous/Auto/Window and the dimension numbers continue to be shown.
However, when I Zoom/Pan, all the dimensions turn into boxes again.
Help Please. "
Re: New user
sand1024
and which version of LC do you use?
Re: New user
Kevin Brown
I am using .....
Version: 2.2.0.2
Compiler: GNU GCC 13.1.0
Compiled on: Jul 29 2023
Qt Version: 5.12.11
Boost Version: 1.75.0
Re: New user
sand1024
well, this is quite old version - why don't you try 2.2.1 or even 2.2.2-alpha?
Re: New user
Kevin Brown
 OK   I'll see where i can download it these versions.   I got my current version from Source Forge.
Do you have any links where I can get these versions including the   ( alpha )   version ?
Reading the above mentioned post i can see that clicking the RH mouse button after the pan zoom restores the dimensions and removes the outline box.
Thank you for taking the time to reply.
Re: New user
sand1024
Re: New user
Kevin Brown
Thank you sand1024
I've loaded this version and given it a quick check.   After pan zoom i am using RH mouse click to restore dimensions.
Version: v2.2.1.1
Compiler: GNU GCC 12.2.0
Compiled on: Feb 18 2025
Qt Version: 5.15.2
Boost Version: 1.87.0
