Tried replying to this thread. Haven't seen an answer, not even in my email. I post the message, several times, ...nothing.
If anyone's interested, the manual says 'Go to Widgets, activate Tool options, check offset." Here, according to the manual, I will get "a distance box" that appears in the tool options bar. A "distance box" doesn't "appear" anywhere. Next step, via the "manual" is to "check offset, select entities, then "enter". Pointless since the preceding steps do not occur as stated in the manual but I proceed as if it had. That does nothing.
BTW, I've also tried re-setting the "offset distance", strictly by the "book" as well as 'experimenting" with the bracketing called for when I try to set distances.
Nothing.
Thanks Pere but it's starting to look like there is no answer
