PDF Exporting Issues
bgonzales
I changed my page size to ledger (landscape) in the drawing preferences, but every time I try to export to .PDF, the result is portrait letter size. I'm brand new to CAD and LibreCAD, so any help at all would be incredibly appreciated. PRINT PREVIEW  RESULTING PDF
Re: PDF Exporting Issues
hi bgonzales,
1, after Current Drawing Preferences to change paper size, File->save is needed;
2, file->Print preview;
3, File->Export->Export AS PDF
please let me know whether this helps?
if not, could you supply a test case dxf?
mdanbury
In reply to this post by bgonzales
Hi,  I've also had pdf export issues.  My problem is that Librecad creates a pdf but the file is empty.  If I keep repeating the export as pdf function eventually it does produce a pdf of the drawing.  Once a drawing has produced a pdf for the first time subsequent exports of the same file seem to work OK.  I run under windows XP.
Regards
Mike
