I need to create the smaller file first. I can't load the entire 30x30 file into the laser it would just tell me out of range.
I've attached an image showing what I'm working with. I can do it manually, but it will be around 50 sheets and that's a lot of work to go through to select and delete every time.
The square in the center is the sheet size I'm working with, which is around 3ft x 7ft.
