Print dialog not appearing
8 messages Options Options
Arlequin
I'm running 2.0.3 on MacOS X 10.9.2.
I used to be able to print but now when I select "Print..." the standard print dialog does not appear. Only the status "Printing Complete" appears in the bottom of the window for a few seconds. This happens with any drawing I create.
I wanted to delete the preferences file because it worked at the beginning but I can't find it.
Any clues ?
Thanks
Re: Print dialog not appearing
is the 2.0.3 a downloaded installer, or macports?
We have printing trouble on windows for Qt-5.2.
Arlequin
I have used the downloaded installer from source forge.
Yet it is strange that I managed to print with this version (or 2.0.2) and that it stopped working on the same version. That's why I want to remove the preferences file but I can't find it.
olbj
1 post
Hello!
I have exactly the same problem with version 2.0.2-36-gad5d577 on os x Mavericks. I mangaged to make one printout and then the print dialog disappeared. The program immediately  reports "printing competed" when I try to print out a drawing.
Best regards Olle
as a workaround, try to build LC by macports.
The trouble we have on OS/X:
Qt4 macdeployqt gives us lots of crashes due to libraries.
Qt5.2 macdeployqt works much better, but gives us broken printer support. Qt5.2 printing problem  was solved in windows by switching back to Qt5.1.
If you can follow our wiki to build LC from source, please test whether Qt5.1.1 works for you.
olbj wrote
Hello!
Best regards Olle
dave177
1 post
I'm having the same issue on Mac OS X with 2.0.3. Other than that, great product.
I pushed a fix to master branch, and back ported this fix to 2.0.3.1.
Please test this installer:
OS/X 2.0.3.1
Arlequin
It works now.
Thank you very much!
> OS/X 2.0.3.1
> If you reply to this email, your message will be added to the discussion below:
> http://forum.librecad.org/Print-dialog-not-appearing-tp5709819p5709906.html
> To unsubscribe from Print dialog not appearing, click here.
> NAML
