When opening Print preview it tries to fit the whole drawing within the paper sheet. You might have a tiny object somewhere off the main elements, nearly invisible, maybe an accidental remnant of some operation. You can find it with Select - Select All.
You can pin Print Preview to 1:1 with marking the "fixed" box, but it's not persistent, just as long as that drawing is opened, I think. It's not possible to set the scale permanently.
