Properties Dialog Box Not Coming Up
Ron64
When I left-click on an entity after activating the properties command, no dialog box comes up. It worked when I first installed it but not any longer. I did a reinstall and it still doesn't work. Any insights would be great.
Thank you,
Ron
Version: 2.2.0-rc3-36-gf094ab36
Compiler: GNU GCC 7.3.0
Compiled on: Apr 29 2022
Qt Version: 5.12.4
Boost Version: 1.65.1
System: Windows 10 (10.0)
Re: Properties Dialog Box Not Coming Up
If something is screwed up it might help to do Options - Application Preferences - Defaults - Clear Settings -All.
Or you have to delete the entries for LibreCAD in the Windows registry, as these are kept when reinstalling.
Or simply mistaken Attributes for Properties?
Ron64
Clearing the settings did it, thanks for the help. I'll set things back one-by-one to where I had them and let you know which setting causes the issue if it occurs again.
Thank you,
Ron
Qt Version: 5.12.4
