Saved blocks not able to be inserted into a new drawing
3 messages Options Options
tony-r
I'm new to libreCAD (LC), but not a total newb to drawing packages, having used MS Visio for a long time.
I'm running the latest LC version, 2.2.0.2-1build3, available on Ubuntu 24.10
I created a simple building plan, created some blocks which inserted without issue into the drawing. I saved the blocks in my home directory. LC knows where they are and they show up in the Library Browser.
However, I've created a new drawing and the blocks wont insert. When selected, I only get the vertical and horizontal cursors, without the rectangle showing the overall dimensions of the block.
This looks like a bug, although it's not beyond the realms of possibility that I'm overlooking something. Any suggestions would be appreciated.
Re: Saved blocks not able to be inserted into a new drawing
perepujal
I'd first discard a missmatching units/scale problem:
Start a new drawing and run the insert block process, if there is nothing in the screen, then do an autozoom
Chances are that View -> Autozoom shows the block and gives a hint about what happens.
Otherwise, then there is a bug, please see if it has already been reported it in github
https://github.com/LibreCAD/LibreCAD/issues
HTH
Pere
tony-r
Many thanks for your reply.
That gave me a clue what might be happening. The blocks I saved were tiny. Scaling them up to the correct size solved the problem.
It's not a bug, just a rookie mistake by someone learning the package.
