Spiegeln Mirror
Spiegeln Mirror
Dieter
Zeichnungen lassen sich einwandfrei spiegeln
Warum wird die Beschriftung nicht mitgespiegelt?
Re: Spiegeln Mirror
One of the features I love is it doesn't mirror the label like most dumb software. This means labels are still readable after mirroring.
Re: Spiegeln Mirror
From top off my head I can't say if this is a feature or an issue.
But what should work is, when you explode the text before mirroring.
Then the letters are converted into single entities which can be mirrored.
But then you also can't edit the text with properties tool, so be sure there are no typos and formatting is correct before exploding.
Re: Spiegeln Mirror
There is already report #813 about a similar issue. When text is already mirrored, LibreCAD interprets it wrong too.
I created feature request #1217 for an option in application preferences whether to mirror text or not.
Then the user can decide himself if text is mirrored or not.
Another solution can be a checkbox in the tool option bar to toggle it quickly while drawing.
