Tangent Curve between existing circle and line
Juniorscone
I Need some help constructing the below shape...
i have no issue creating the 2 tangent curves from the end of each of the straight lines
However, how do you then get the 2 curves to them meet at their tangent also?
Re: Tangent Curve between existing circle and line
Modify - Fillet  (with Trim, and radius set at the Tool Options bar).
emge25
In reply to this post by Juniorscone
the solution need some calculations
See the image
The center of arc is on the line AB
C, O and T are aligned
AB and OB are known
The radius of arc is the sum of CO and R
CO is calculated by Pytagore theorem
Finaly we obtain the équation at the bottom of the picture
Solving this équation is easy placing the square root in a side and the rest on the other by sqaring all. We obtain x = 262.5
The radius of the arc is 150 + 262.5
Point C is the center of the arc.
