Text does not show up
7 messages Options
ML1965
Hi I need help.  I have been trying to add text and dimensions without success.  It shows only a empty box.  I played with text dimensions without succes.  I can see the files .lff in the directory ..librecad/ressources/fonts.  I put this path in librecad under application preference. I tried to re install librecad  Nothing work  What can I do to have the text work?
Re: Text does not show up
sand1024
check whether draft mode is disabled. In Draft mode the text and hatch objects are not drawn (as well as all lines are 1 px) The switch for draft in menu depends on the LibreCAD version, yere there should be a button on the main toolbar.
hans-odnv
In reply to this post by ML1965
tekst wordt niet geplaatst.
hans-odnv
Het zelfde probleem als ML1965
Alle tekst niet te lezen. alleen een lege rechthoek
Re: tekst
The drawing tabs say you have Draft Mode enabled. Switch it off.
It seems you have removed the icon bar containing it's icon. You can find the command also at View (Beeld?) - Draft or by keyboard with Control+D.
Re: tekst
hans-odnv
Thank you!!!!
Re: tekst
In addition, the "Draft" can be seen in the corners of the view
