Trim
Trim
Dermott
Has anybody else had a problem when trying to Trim using two 'cutting/trim' edge? When I select this option in the command prompt it states to select the first trim edge (once selected this the entity changes colour). The prompt changes to select the second trim edge, when this is selected nothing happens and the command is aborted.....any ideas?
Note Triming using one cutting edge works fine
Dermott
Re: Trim
I can only reproduce this if the second trim entity is on a locked layer. Otherwise no idea.
Re: Trim
Hal_v_1937
G'day,
"Trim using two cutting edges"?
What ever selection method I try the command line will only "allow" the selection of ONE limiting entry, before calling for "Entity to trim".
I'd appreciate it greatly if someone give could me some help on selecting more than one cutting/limiting edge.
Hal.
Re: Trim
It's some time ago, but I must have misunderstood Dermott's question, thinking he was talking of the "trim two" command.
Indeed you can't trim an entity on two sides in one step.
