Tutorial doesn't match application #2
3 messages Options Options
LinuxMint
On linuxmint 17.2
SCM Revision: 2.0.2
Compiler: GNU GCC 4.8.2
Qt Version: 4.8.6
Compiled on: Jan 29 2014
Following the tutorial http://wiki.librecad.org/index.php/LibreCAD_users_Manual#Drawing_lines
"Changing Line Properties
2.  Once you have this, go ahead and click on modify on the menu bar. On the pull down menu, select properties. "
There is no Properties menu under Modify.
There is 'Same properties' and 'Attributes' that perhaps may apply.
But they don't do anything: selecting any of them then clicking on the line does not bring up any requester. The line is selected but nothing else happens.
Thanks.
Re: Tutorial doesn't match application #2
The feature exists; see if you can download a more recent version.
Otherwise you will have to build from source.
LinuxMint
Thank you ravas for the quick reply.
Following the installation instructions of the latest stable release on http://librecad.org/cms/home/installation/linux.html
LibreCad was updated to :
Version: master
SCM Revision: 2.0.4
Qt Version: 4.8.6
Compiled on: Jun 24 2014
The menu items and thus the problem are still the same.
I also noticed on the https://sourceforge.net/projects/librecad/ page that there is no activity on the *nix line. At least not for the last two months.
Is the *nix line dead?
Best regards,
Bill
