Hello all,
this seems to be a perennial problem, one which I feel may have a now forgotten solution. I can't snap to the intersection of two inscribed ellipses. It's an intermittent problem, sometimes it works and sometimes it doesn't. For example I just went to make an example drawing to accompany this post and I could snap to the intersection of two inscribed ellipses in that drawing, but it does not work in the drawing I have linked below. I don't know how to recreate the problem, but I've had it a few times since I started using LibreCAD. Any help appreciated. Link to an example .dxf file -> https://drive.proton.me/urls/FH8GGYHE0G#mnGIFy2iXr3K EDIT: so I've just opened the above drawing in LibreCAD running on top of Debian 12 and snap intersection works on the ellipses there, but it doesn't work on Windows 11. However, I have had this same problem in the past on Debian 12, so I don't know what specifically is different now I've tried on a different OS. |
This is a major issue we would like to address, but technically, it's a quite difficult problem without using a topological layer. In summary, we try to find tangent points as intersection. For example, given a circle and one line tangent to the circle. While it might be obvious to identify the tangent point as an intersection, CAD relies on solving the equations of the line and the circle to find common solutions. When a line intersects with the circle, two solutions can be found, so intersections are found reliably. When there's no intersection, no solution is found, and that's just what is expected. When they are tangential, the equations are still being solved, but as we do everything with floating points, with rounding errors. The system may find two solutions, one solution, or no solution at all. That's exactly the root cause of finding intersections appears to be random for the end user, as you observed. Without going into the details of equations, just imagine a circle and a tangent line of it, now, both the circle and the line have some uncertainty due to rounding errors, so there are always some random noises added to both of them, in positions, radius, etc. then, you can pick 2 intersections, 1, or none. Possible solutions: 1. Create a topology layer, so the system will remember coincidence and tangential relations; 2. actively find tangential points, and add them to intersections. We do have reliable ways to find tangent points, by using dual curves from projective geometry, so finding tangent lines becomes finding intersections for dual curves. We do know what won't work, blindly increasing the precision level of equation solving. This is an issue at the conceptual level, not only at the implementation level. Workaround: try to create tangent lines, and snap to end points instead of intersections.
In reply to this post by Tonyeltigresa
Thanks for the detailed reply!
I wont pretend to understand all of it, but I'm sure that at some point it will be of use to someone who does. I've no idea how typical my own requirements are, but I'd imagine the geometry I'm trying to draw is somewhat common. It would be great if snap to intersection worked reliably with inscribed ellipses because it's really the only bug I've encountered that has a material impact on the programs usability. I'll try the workaround and report back. |
Adding the link to the original GitHub discussion
https://github.com/LibreCAD/LibreCAD/issues/523
I will quickly add fixes to 2.2.1:
1, if no intersection is found, check for tangent conditions; 2, since the tangent condition is not actually decidable with rounding errors, without a topology layer, we are going to allow false interactions, but avoid missing real tangent points. Due to rounding errors, a tangent line of a circle may see random noises in position relative to the circle. We will accept tangent points whether 0, 1, 2 intersections are found. It means even if the line is actually 1e-6 from closest point on the circle, a tangent point will be identified. Depending on the tolerance level, we are going to report intersections from two close but not contacting curves. The basic idea, it's acceptable to report a false interaction, but not acceptable to miss a real one. If there's no objection, I will add this to 2.2.1 and quickly release 2.2.1 as the latest stable.
