Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I thought I was. Refer to "https://github.com/thoughtbot/capybara-webkit/wiki/Installing-Qt-and-compiling-capybara-webkit" web page. I got there because I was trying to install Qt because the install instructions on "http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source" for building from downloaded source said to install Qt and new gcc. So after installing Macports (needed to install Qt), the installation for Qt using Macports says to:
sudo port install qt5 # It's not qt5-mac anymore. That worked, so the next part of the instructions then say: The default location for qt5's qmake is /opt/local/libexec/qt5/bin/qmake. If the qmake on path is different, you can indicate the correct one with QMAKE environment variable. QMAKE=/opt/local/libexec/qt5/bin/qmake gem install capybara-webkit So that's why I did it. Qt appears to be installed and functional. But none of the examples are there to learn how to use it, nor are the help or man pages. The on-line manual pages will take some time to browse through for specifics on how to use Qt. However, I did load the ~/github/LibreCAD/librecad.pro file into Qt and am able to browse through the source files and even bring up the GUIs. So I can now do some of the research I need to do even if the installation isn't quite correct or complete. I should also mention that I attempted to run a debug session via Qt, but it didn't compile. I got over 58000 issues listed; and it quit outputting to the "Compile Output" window. (I guess it knew I wasn't going to read through all that stuff anyway. ![]() -- DErik -- |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hi DErik,
please read through our wiki, even though updates are needed, like package names changed, executable paths changed, etc. The building process for LC is still by qmake. also, read the building scripts come with LC in LC source folder: scripts/build-osx.sh
... [show rest of quote]
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on Feb 03, 2016; 3:21am.
In reply to this post by DErik
https://github.com/LibreCAD/LibreCAD/issues/634 In case you didn't figure it out, custom.pro is a file you make. The information is only in the Windows section http://wiki.librecad.org/index.php/Build_from_source#Custom_files |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Correction: "...custom.pro is a file you edit."
https://github.com/LibreCAD/LibreCAD/blob/master/librecad/src/custom.pro I'm getting a Mac in a few days, but you will probably have this figured out by then... ;-] |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I get a 404 on the above link
-- DErik -- |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Where should the custom.pro reside, if it is supposed to be on the OS X platform at all? And should it include references to the boost directories in it? I don't have boost installed anyway. Do I need it on Mac?
-- DErik -- |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
for the time being, try to build LC without using custom.pri (preferred over custom.pro).
Yes, boost is required dependency for LC. You can easily install boost in MacPorts, and without any manual configuration to use the boost library. Try to follow http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_LibreCAD-2.0_on_OS.2FX
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I got my new iMac today.
Here was what I did: - downloaded 2.0.8 (yosemite dmg) -- installed and opened with no problems - installed macports and tried "sudo port install librecad" -- it failed after a while with: - downloaded qt 5.5.1 from the Qt website and installed with no problems -- however it complained about needing Xcode - downloaded the latest Xcode beta (5gb :O) and installed with no problems - then in the terminal: $ sudo xcode-select -switch /Applications/Xcode-beta.app/Contents/Developer $ sudo xcodebuild -license - built librecad in Qt creator in release mode using clang and all the defaults... with 50k+ non critical issues -- when the program launched after building it seemed to get stuck on the loading screen however, behind the loading screen was a dialog claiming that "plugins/plugins.pro is not a valid Mach-O binary" and then the same for plugins.sln and README.plugins -- showing then hiding a window will also hide the loading screen so you can see those dialogs More research is needed; and I'll try gcc and the building instructions on the wiki tomorrow... needing sleep. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I remember qt5/clang worked for me on 10.9. on 10.8 and gcc, the macports hack was needed (see our wiki).
it's probably easier to fix the MacPorts package(the MacPort package, instead of the referring to the said gcc hack) first. Ries knows better here. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Adding GCC into the process seems like an unnecessary complication for OSX.
By default Qt creator is set up to use Clang, and as far as I understand it LLVM. It builds fine... it just outputs a lot more warnings than gcc. These can be suppressed by adding to src.pro: QMAKE_CXXFLAGS_WARN_ON = -w or just one of the big offenders QMAKE_CXXFLAGS_WARN_ON = -Wno-inconsistent-missing-override Although, it's probably smart not to commit those, incase someone is inspired to deal with the 50k issues. The issue is that on start up 4 dialogs are presented that say: '/Users/one/Documents/LibreCAD/plugins/Makefile' is not a valid Mach-O binary (invalid magic 23232323) '/Users/one/Documents/LibreCAD/plugins/plugins.pro' is not a valid Mach-O binary (invalid magic 232d2d2d) '/Users/one/Documents/LibreCAD/plugins/plugins.sln' is not a valid Mach-O binary (invalid magic 4d696372) '/Users/one/Documents/LibreCAD/plugins/README.plugins' is not a valid Mach-O binary (invalid magic 46697273) Any idea why this would be happening? The program successfully loads after dismissing these dialogs. I don't even understand why these would be processed as Mach-O binaries, or where. I did try compiling with gcc; however it always complained about unique_ptr not being part of std, which I guess has something to do with c++11... My research showed suggestions for: # QMAKE_MACOSX_DEPLOYMENT_TARGET = 10.11 # QMAKE_CXXFLAGS += -mmacosx-version-min=10.7 # QMAKE_CFLAGS += -mmacosx-version-min=10.7 # QMAKE_MAC_SDK = macosx10.11 # QMAKE_CXXFLAGS += -std=c++11 -stdlib=libc++ # QMAKE_CFLAGS += -std=c++11 -stdlib=libc++ # CONFIG += c++11 Although various tweaking of the values never solved the issue. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
It seems the following is preferred: CONFIG += warn_off http://stackoverflow.com/questions/18667291/disable-wall-compiler-warnings-in-a-qt-project http://doc.qt.io/qt-5/qmake-variable-reference.html#config Curiously it will still say: Project ERROR: muparser development package not found Yet the cal command seems to work. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
since muparser is included in LC by source as well
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
But why produce an error message? Where is it coming from?
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Sorry, guys. Been busy with other things for a while. What ravas describes about the errors seems to be pretty much what I encountered. In particular, I recall the problem about unique_ptr not being part of std. I just figured it was a bug you hadn't gotten to yet, so didn't worry about it. But it kept the thing from completing the build, so the .app never got created. Hopefully I'll get to some more of it tomorrow. Will be pretty busy today as well. Thanks, DErik
... [show rest of quote] -- DErik -- |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I am working on Amazon Web Services EC2, would there be a place for said EC2 in development? From my readings and study of EC2, developers do use it.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
LibreCAD is a C++ / Qt project.
https://en.wikipedia.org/wiki/Qt_(software) |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Yes I know, are you saying AWS (Amazon Web Services) can not help?
---- On Tue, 09 Feb 2016 22:57:04 -0500 ravas [via LibreCAD] <ml-node+s1049103n5712939h63@n5.nabble.com> wrote ---- LibreCAD is a C++ / Qt project. https://en.wikipedia.org/wiki/Qt_(software) If you reply to this email, your message will be added to the discussion below: http://forum.librecad.org/dev-environment-setup-and-usage-tp5712883p5712939.html To start a new topic under LibreCAD-dev, email ml-node+s1049103n4361976h10@n5.nabble.com To unsubscribe from dev environment setup and usage, click here. NAML |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
We can do pretty much anything with the framework we are using;
it's just a matter of doing the work. Start a different topic if you have ideas you want to discuss regarding this. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
If I remove plugins.pro, plugins.sln and README.plugins from my local repository,
then when I open the .app file it will not produce those "is not a valid Mach-O binary" dialogs. So the question is: why would the app file be looking in the repository for those files? |
