dimensions have no text
cantcode
When I draw a dimension in LCad, the dimensions have no text.
When I add text to the drawing there is no text, but when I select everything I can see a blue dot (center/start point of the text) where the text was added.
Can someone reproduce it or is this already known?
ubuntu12.04
SCM Revision: 2.0.0rc1
Compiled on: Jun 22 2013
Image and video hosting by TinyPic
Re: dimensions have no text
claus82
Hi, try to checkif the size of the text is too small to be visualized or check if the standard.lff font is in the font directory.
Bye!
cantcode
The problem was the way I build LCad. That way LCad could not find the fonts.
Thanks for the hint.
claus82
Did you solve the problem man?
cantcode
yes
claus82
GOOD!
See ya!
Cla
