Hi there!
I just started using LibreCAD. I constructed a rectangle via the command line. Thus I am sure, that it has the correct sizes. One side for example mesuares 79.5 cm.
When I try to add the dimension by clicking the start point and the end point of this side I hardly get the 79.5 cm but something like 79.44, 79.52 and so on.
I know that I can change the accuracy of the dimension results that are shown to just 1 decimal place but to me that does not seem to be a good solution as that would just hide my measuring mistakes.
Isn't there a way to kind of asking LibreCad to read the lenght of a side? I mean, LibreCad knows the lenght - do I really need to try to measure it manually which is so error-prone? Is there any better way?
Thanks a lot!
Eduard
