horizontal and vertical dimension [resolved]
10 messages Options Options
magicman
This post was updated on Jan 14, 2015; 9:12pm.
Hi everybody.
I start to work with libreCAD (an amazing free ware) and i've got a problem when i copy "horizontal or vertical dimension" (cotation in french)
the copy or cut works good but the size of texts changes ! i mean my text original is "normal size" and the paste text is very very small.
I would like some help because i don't understand why copy/paste changes that !
Thanks for yours help
Re: horizontal and vertical dimension
Can you supply a test case dxf and steps to show this bug?
magicman wrote
Hi everybody.
magicman
Hi
can i insert dxf file ? i mean no so i made a screenshoot of my problem
you can see easily 30 in the first dimension.
after copy/paste the size of this one is very very little ! i did nothing more, just copy and paste.
I include preferences of my projet.
Thanks for your back
can not reproduce this bug.
To attach a file in post, select the "More" tool button in the composing page, similar to how you use "Insert Image" button to insert an image in your post.
magicman
ok,
i send my test file.
test.dxf
I hope you can find my problem
thanks lot
what's the version of LibreCAD there?
Using the latest master branch (roughly the same as 2.0.7 release) I can open your test.dxf file properly, seeing both dim entities with the same proper text size.
magicman wrote
ok,
test.dxf
thanks lot
my LibreCAD version:
Version: master
SCM Revision: 2.0.7-11-ga372d3d
Compiler: GNU GCC 4.8.4
Qt Version: 4.8.6
Compiled on: Jan 11 2015
Portions (c) 2011 by R. van Twisk
Program Icons Supplied by
   Pablo: LibreCAD Argentine
Splash and Logo supplied by
magicman
my version
Version: master
SCM Revision: 2.0.7
Compiler: Clang 6.0.0
Qt Version: 5.4.0
Compiled on: Jan 3 2015
i found a solution !!!!
i explain
when i start my project i changed "general factor" and "general scale"
when i copy/paste the text size is very very little, in fact the text became at factor and scale 0,1 (it seems). BUT if i go to drawing preference and just clic on Ok in the window (no change), the size become normal !
why ? i don't known, maybe with yosemite (mac computer) there is a bugg.
anyway it's work ! i can make many copy and many paste. and at the end i can change the size of my dimension.
that's great
Thanks lot for your help !
Seems to be a corrupted preference file.
what's puzzling is that the values in the Preferences Window are correct. Pressing OK would rewrite the preference file, and correct the underlining problem.
magicman wrote
my version
Version: master
SCM Revision: 2.0.7
Qt Version: 5.4.0
i explain
that's great
magicman
So i have to make something to delete this problem ?
my action for change size is very easy to do.
if i can do something, i will :-)
