message inside Librecad
JWtH
LS,
If I insert a dxf file, got from an other user, Librecad freeze.
I've to wait or end the programm.
After that I got a message:
Versie: 2.2.0-undef
Compiler: GNU GCC 13.2.0
Gecompileerd op: Apr  8 2024
Qt Version: 5.15.13
Boost Version: 1.83.0
System: Ubuntu 24.04.1 LTS
What do I heve to do for a good running LibreCad
Re: message inside Librecad
Maybe sharing the file?
JWtH
The problem is stiil on board.
When opening a dxf file I see the drawing. If I try to copy a selection for moving to another layer the programm chrashed. I have to wait or stp the programm.
I happens with all the dxf files I open with this version of Librecad
sand1024
Well, please try open the file using latest version of the LibreCAD
(say, https://github.com/LibreCAD/LibreCAD/releases/tag/2.2.2_alpha-latest).
If the problem with opening still exist - please share any file where it occurs. Without actual data I'm afraid it will be not possible to address this issues.
JWtH
Thanks for the info.
I've explode the dxf and all lines were great.
Maybe is the pdf not convert good to dxf.
With ? programm can I the pdf's to dxf for using librecad?
