only empty boxes/frames are shown for image/text? no line thickness?
Next Topic
13 messages Options
You need to disable "Draft" mode. Make sure you uncheck the following item:
Main menu: View->Draft
Re: only empty boxes/frames are shown for image/text? no line thickness?
sp1der
The Icon has changed since version 2.1
dcas2020
Thank you Lord of Bikes,
 ' draft ' mode was set and  causing my problem,
cleared it and OK now.
cheers,
Denis
follaiv@alice.it
Thanks a lot I solve the problem by click on the Draft Mode as you suggest
I the latest development version, "Draft" will be shown on in the corners of the drawing view. Hopefully, we will confuse users less.
PatrickNC
To dxli: I just read your message about new "Draft" messages, 4 months later.  I'm still reading posts about dimension problems while printing.  Always issues in software development between including it one simple way versus alternative options.  At least a "Draft" message of some sort get users onto a track to a solution. I'm not sure how well it will work but at least it's an effort to address the problem.
Christian
I do have the problem of text (dimensions or TEXT tool) only showing an empty rectangle while  draft mode is NOT ON.
At the moment I am stuck.
Well I am now unstuck: I just closed the program and re-opened it. It was just a local bug (the bugger!)
Matter closed for me
Micke77
Dziękuje bardzo.
Micke77
Dziękuję za pomoc, pozdrawiam.
In reply to this post by Christian
Please note, when the rendered text is determined to be too small (consider the extreme, if the whole text is only 1 pixel in height), only a bounding box is drawn, i.e. the behavior of Draft mode.
Christian wrote
pkemner
I'm having a similar problem.
Version: 2.2.0-undef
Compiler: GNU GCC 13.2.0
Compiled on: Apr  8 2024
Qt Version: 5.15.13
Boost Version: 1.83.0
System: Linux Mint 22.1
I open librecad and load my drawing.
I add a dimension line. The measurement appears.
I pan the image- all measurements change to empty boxes.
Save the image, exit, reopen librecad and open the drawing- the measurements are there.
I can select a window or zoom out or in, and the measurements are still there. If I pan the image, it's all empty boxes.
Urstein
Does turning on draft mode only display dimensions and text as rectangles to reduce the screen rendering burden and make the screen more responsive? Is this the same effect as classifying dimensions and text into layers and hiding those layers?
