re-do menu bar?
Next Topic
7 messages Options
re-do menu bar?
micheletrecaffe
I've just installed Librecad 2.2 and to be honest, I really dislike the menu. I don't need the Plugin, Widgets, Drawings menus at all. I could also easily do without Options, Edit and View.
What I DO need are the actual tools for drawing: the various headings under 'Tools': a 'Draw' menu containing "line" "circle" etc; 'Modify' (the actual tools I work with to alter existing elements); the 'Selection' menu; the 'Dimension' menu and the 'Information' menu.
Is it possible to re-work theings so that my main menu are the elements I actually need for the purposes of creating and altering drawings? And put all the extra stuff into a submenu somewhere?
Thanks!
Re: re-do menu bar?
currently, the menu entries are not under user settings.
The toolbars are highly configurable though.
It's conceivable to set up a full screen mode:
1, full screen mode without menu entries;
2, add a context menu entry (Exit Full Screen).
Thanks!
Re: re-do menu bar?
micheletrecaffe
Here is what is crazy, tho: Librecad was once set up exactly this way, back in the 2.0 days. The main menu was, in fact, a *working* menu, where the tools needed to do the work made up the bulk of the first-level menu entries.
Now, I could download a tarball from the official repository for one of those versions, fight for a couple days to build a qt version that would work with the selected LC version and then build with gcc or...
...Or I can download the windows exe installer, open it with wine and twenty seconds later have a fully functional  Librecad up and running. And when I say 'fully functional' I mean fast and stable under wine.
Which really feels like "user-freedom" Linux shooting itself in the foot by making this whole process so cumbersome.
Anyway, for now I am going to use 2.0.11 under wine because it gives me a working menu, it's stable, it's fast and I have just saved myself hours (or days) of wrangling.
Re: re-do menu bar?
sand1024
Well, while menu is not fully customizable, in
2.2.2-alpha (https://github.com/LibreCAD/LibreCAD/releases/tag/2.2.2_alpha-latest) you may select it's form:
1) compact (by default)
2) medium (with separated draw/modify items) - slightly more expanded, like
3) detailed one - something like this:
Re: re-do menu bar?
sand1024
oh, and regarding the menu - in 2.2.2-alpha it's also possible
1) create sophisticated context-aware popup menus (for various shortcuts and that may be custom for specific entity type)
2) hide main menu completely (as this functionality will be merged to master)
Re: re-do menu bar?
micheletrecaffe
Of course, what you are talking about is creating a pop-up menu to do the meat and potatoes of any design program, while the main menu is taken up with whistles and bells, which is... odd.
Imagine driving a car where the odometer, speedometer, gps, etc., were pop-ups while the main dash was, I don't know, a button for siri/no siri; a map showing the location of the nearest cinemas and eateries; and maybe a do-dad to show the rotational speed of the tyres at any given moment...
Re: re-do menu bar?
sand1024
hm.. popup is just an additional way. But if you use menu in expanded form in 2.2.2 - it will be basically the same as you've described plus some additions.
Also, if, for example, we remove Options and Workspaces menu items from main menu - how they will be accessed by the user?
