Like polylines, splines are also not valid as limiting entity for trimming.
Splines are much more complex and intersection math, which is needed for trimming, is not implemented for them. Also splines could not be exploded.
You can try to start with an empty drawing. Draw two simple intersecting 2-point lines and test how trim or trim-two works with them.
This should eliminate any possible issues which may prevent trimming in your existing drawing.
