From the site, I just the method to fetch/build LibreCAD by ubuntu.
Does someone know how to get the code/ build LibreCAD and redhat linux ? By the way, how to get "git" seriels command worked ? Thanks for your help. I think I might be an expert with your help :) |
yes
wingame82
Date: 2012-11-20 09:14
To: [hidden email]
Subject: some questions about fireup for leaning
LibreCAD From the site, I just the method to
fetch/build LibreCAD by ubuntu. Does someone know how to get the code/ build LibreCAD and redhat linux ? By the way, how to get "git" seriels command worked ? Thanks for your help. I think I might be an expert with your help :) If you reply to this email, your message will be
added to the discussion below: http://forum.librecad.org/some-questions-about-fireup-for-leaning-LibreCAD-tp5707240.html
To
start a new topic under LibreCAD-dev, email
[hidden email] To unsubscribe from LibreCAD-dev, click here. NAML |
In reply to this post by Johnson
Hi, Ries
Thanks for your quick bring-up. I will catch hold of Rallaz if I saw him
online.
Sorry for the typo. I mean how to install Git on Linux.... I am sorry I am
really a beginner for Linux.
Thanks.
wingame82
Date: 2012-11-20 09:33
To: [hidden email]
Subject: Re: some questions about fireup for leaning
LibreCAD Hey,
in reality it just's a couple of dependencies you need to meet. The
dependencies can be found in the Ubuntu apt-get commands.
I believe redhat works with yum, or up2date and I believe most packages
should be in there respected repositories.
If anything fails, see if you can reach-out to Rallaz. he lurks on this
mailing list as well as on the IRC channel.
What di you mean with ["git" seriels command worked]
? Ries On Nov 19, 2012, at 8:14 PM, wuxinjiang [via LibreCAD] wrote: From the site, I just the method to fetch/build LibreCAD by ubuntu. If you reply to this email, your message will be
added to the discussion below: http://forum.librecad.org/some-questions-about-fireup-for-leaning-LibreCAD-tp5707240p5707242.html
To
[hidden email] To unsubscribe from some questions about fireup for leaning LibreCAD, click here. NAML |
Thanks very much . Let me have a try :)
wingame82
Date: 2012-11-20 10:20
To: [hidden email]
LibreCAD Hey,
If you use a version of redhat you will properly have yum install,
then you can install git with : yum install git
yum search <name> allows you to search for packages (without < and
The cmd get's a bit used to, but once you have some basics, it's really
easy.
I am pretty sure there are GUI tools for redhat aswell, I just never used
them
so I cannot help you there.
added to the discussion below: http://forum.librecad.org/some-questions-about-fireup-for-leaning-LibreCAD-tp5707240p5707244.html
To
For rpm packages see:
https://github.com/Rallaz/LibreCAD/wiki/Rpm-packages LibreCAD are packaged for RHEL 6, the src.rpm are in: http://download.opensuse.org/repositories/home:/Rallaz/RedHat_RHEL-6/src/librecad-2.0.0beta1-1.1.src.rpm Unpacked files: https://build.opensuse.org/package/files?package=LibreCAD2&project=home%3ARallaz This src.rpm require Qt4, of course, xz, muparser & libdxfrw More info in this thread: http://forum.librecad.org/Redhat-system-recompile-LibreCAD-tp5706714.html Remember dxflib no more needed. Cheers, Rallaz |
there's git support within qtcreator. install git and try to do git in qtcreator. dxli On Nov 19, 2012 9:20 PM, "R. van Twisk [via LibreCAD]" <[hidden email]> wrote:
Hey, |
Today I decide to use Ubuntu system to start the programming and
learning. All done. Thanks Rallaz anyway.
wingame82
Date: 2012-11-20 15:41
To: [hidden email]
Subject: Re: Re: some questions about fireup for leaning
LibreCAD For rpm packages see: https://github.com/Rallaz/LibreCAD/wiki/Rpm-packages LibreCAD are packaged for RHEL 6, the src.rpm are in: http://download.opensuse.org/repositories/home:/Rallaz/RedHat_RHEL-6/src/librecad-2.0.0beta1-1.1.src.rpm Unpacked files: https://build.opensuse.org/package/files?package=LibreCAD2&project=home%3ARallaz This src.rpm require Qt4, of course, xz, muparser & libdxfrw More info in this thread: http://forum.librecad.org/Redhat-system-recompile-LibreCAD-tp5706714.html Remember dxflib no more needed. Cheers, Rallaz If you reply to this email, your message will be
added to the discussion below: http://forum.librecad.org/some-questions-about-fireup-for-leaning-LibreCAD-tp5707240p5707246.html
To
