2.2.1_rc and 2.2.2_alpha are ready to test
23 messages Options
12
Re: 2.2.1_rc and 2.2.2_alpha are ready to test
Appears to be font issue. It could be the font data or the font implementation.
I did some troubleshooting, the Text implementation is simply sending scaling factors to the font entities, so unlikely be causing this bug.
If different scaling factors are used for x- and y- directions, the scaled letters are messed up.
usuario wrote
I'm using a translator.
Yes, it works much better, thank you.
While it is being improved, could the Text tool be temporarily removed?
Thank you for your work on LibreCAD.
Best regards.
In reply to this post by usuario
The problem is using arcs in fonts.
The current LFF fonts contain polylines, and a polyline by definition may contain arcs but not elliptic arcs.
The width factor of Text may scale the font differently in x-/y-directions, if the factor is not 1. That means any arcs will be scaled into elliptic arcs. However, the polylines can only be scaled as arcs, leading to inconsistent shapes.
Workaround: if you do need to scale fonts wider, explode the text and scale the entities.
Or, try to use a font which doesn't contain arcs (if you read the lff file for the character, to avoid arcs, the font data should not contain any coordinate starting with the letter 'A', like 'A1'. For example , the standard.lff for the letter [0042] 'B' contains arcs in fonts😭
Thanks for your work in LibreCAD, the link shows erratic behavior of the Text tool of the Dimension dockwidget.
https://youtu.be/oGRxh51QI9s
LibreCAD is great software!
Version: 2.2.1_rc2-8-g0649fad1
Compiler: GNU GCC 12.2.0
Compiled on: May 31 2024
Qt Version: 5.15.2
Boost Version: 1.75.0
Similar behavior is found in version 2.2.2 alpha.
Best regards.
usuario
* I am using a translator.
Thanks for checking the behavior with the fonts, for now I was able to solve it using the MText option, when required I will try the solution proposed here.
I hope you can continue contributing your knowledge to LibreCAD.
Best regards.
12
