Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hi, 1) hide some layers. 2) select some drawings from other, visible layers 3) click some hidden layer to become visible Boom! All your drawings got cramped to that layer you once u click it. If I have something selected and then change to some other layer (visible or not) all the drawings just jump there. The WORST thing is that undo does not undo this! All layer info got lost. What's going on? ..please help. My system: Linux mint 17 I have added repository librecad-stable (deb http://ppa.launchpad.net/librecad-dev/librecad-stable/ubuntu trusty main) and installed in synaptic (shows 2.0.4-1~dialy~ubun) Program says: Version: master SCM Revision: 2.0.4 Compiler: GNU GCC 4.8.2 Qt Version: 4.8.6 Compiled on: Jun 24 2014 |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This was implemented as a feature.
I will make sure this feature is NOT enabled by default. We also need a GUI support to enable/disable this feature.
... [show rest of quote]
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on May 12, 2015; 2:21pm.
In reply to this post by joonasr
I added an option to enable/disable this feature in :
Edit->Application Preferences->Default->Modify layer of selected, at layer activation TODO: add attributes to undo cycles
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Feature ..uh :) I bet very few new users expect changing layer, especially visibility of a layer, to have such a dramatic effect. So it will be impossible to disable until some new stable version appears, someday? Librecad is truely a great program but there is a few un-intuitive features. I wonder eg. is there some reason why this moving the selected -feature does not work with an inherent optionality. Like: "select stuff" -> "right click a layer" -> "choose from: copy here, move here, create a block and copy here, some crazy extra option..." or something like that? Why the right click dialogue box seems to be "banned"? |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I checked. The code clearly says the feature is disabled by default.
If you are running the latest release (2.0.7), or the latest development, you can clean up all local settings: 1, close all running instances of LibreCAD; 2, rm all LibreCAD setting file, information of the file location: http://doc.qt.io/qt-4.8/qsettings.html 3, start LibreCAD LibreCAD is using all default settings now.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I'm pretty sure I have it on as a default. Can I turn it off? |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I also assume that the shifting of drawings on the "selected layer" when toggling a visibility of some layer is not really an intended part of this feature. I get it that it is a handy way to move things around, though I would rather want to copy, but toggling visibility is necessary for other operation as well. You cant: 1) hide helper lines 2) rubber band your target drawings 3) select operation, like copy 4) toggle on visibility of the helper lines to snap.. boom! Maybe this would work really nice if, say, ctrl button could toggle do you want to move or copy the "selected layer" and only clicking the layer (name) itself, not visibility, would do the action. Cherry on top, there would be a tooltip telling you what will happen if you click a layer you're hoovering on. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I wasn't aware of this feature until reading this thread. However, I'm guessing it was implemented to mirror Autocad functionality (select objects, then select the layer you want -> moves objects to that layer). The visibility aspect I don't understand; and I was not able to reproduce the behavior with the Nightly build from yesterday. I will test with the latest commit within the next few hours.
There is a more intuitive way to change the layer of an object: Modify -> Properties Unfortunately this is relatively hidden... I have suggested making it a top level icon or making a command or hotkey for it. Right click in LibreCAD steps back in the current tool operation, and then once out of the operation it steps back through the toolbar menu.
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
There is no need to test this.
In LibreCAD 2.0.4, build on Jun 24 2014, the version joonasr is using, this feature was fresh implemented, hard coded switched on. As other users struggled with it, it was reverted a couple days later. Then it was reimplemented as option that is default off, a few day after. But there was no GUI option to switch it on, only by hacking config file. The problem is, that the Linux stable ppa got stuck on this version. To use newer version joonasr has to use the daily ppa or build from source himself. Meanwhile dxli has added a GUI switch for this option, but as said before, for Linux only usable by daily ppa or build from source. Armin
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Oh I see...
I tested anyhow. :D I see what he is saying about the visibility aspect. If I have a circle selected in layer 0 and press the visibility icon on layer 1 then the selected circle is moved to layer 1. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
I updated to "daily build" and after activating this feature all lines still move when toggling visibility, which, I assume, is not intended. Like I said this would work really nice if, say, ctrl button could toggle do you want to move or copy the "selected layer" and only clicking the layer (name) itself, not visibility, would do the action. Cherry on top, there would be a tooltip telling you what will happen if you click a layer you're hoovering on. Currently there are no cues of what is going on for the user. Needless to say the undo is must to have. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
The problem is that clicking any icon related to a layer activates that layer.
The same thing will happen if you click the lock or construction icons. The hotkey idea could work. Two other options that I think would be acceptable: 1. when you right click on a layer the context menu has "move selected to this layer" 2. make a hotkey, command and/or top level icon for Modify → Attributes |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
added this action to undo:
https://github.com/LibreCAD/LibreCAD/commit/f7cc379d41a654c15b7e8e29524c58b3a4e35c69 |
