New LibreCAD user (developer?) on OSX here.
I tried several (free) CAD applications to load my rather large dxf file (110mb. > 100000 entities). LibreCAD was the only application which succeeded in doing so. Next step for me is to to build LibreCAD from the source, but I am getting an error. I installed boost with homebrew and muparser from the source. Build output: bash-3.2$ ./scripts/build-osx.sh ++ dirname ./scripts/build-osx.sh + SCRIPTPATH=./scripts + cd ./scripts/.. + rm -rf LibreCAD.app + qmake librecad.pro -r Reading /Users/gertwin/work/LibreCAD/LibreCAD.source/libraries/libraries.pro Reading /Users/gertwin/work/LibreCAD/LibreCAD.source/libraries/libdxfrw/libdxfrw.pro Project MESSAGE: We will be using CPP11 features Reading /Users/gertwin/work/LibreCAD/LibreCAD.source/libraries/jwwlib/jwwlib.pro Project MESSAGE: We will be using CPP11 features Reading /Users/gertwin/work/LibreCAD/LibreCAD.source/librecad/librecad.pro Reading /Users/gertwin/work/LibreCAD/LibreCAD.source/librecad/src/src.pro Project MESSAGE: We will be using CPP11 features Project MESSAGE: Found Boost in /usr/local Project MESSAGE: Using Boost includes from /usr/local/include Project ERROR: Package muparser not found I saw in muparser.pri the library is located with pkg-config. In my case pkg-config can find it: bash-3.2$ pkg-config --cflags --libs muparser -I/usr/local/include -L/usr/local/lib -lmuparser Any ideas why qmake does not find muparser? Thanks, Gertwin |
In reply to this post by Gertwin
You may try to set in librecad/src/muparser.pri:
MUPARSER_DIR = /usr/local INCLUDEPATH += "$${MUPARSER_DIR}/include" LIBS += -L"$${MUPARSER_DIR}/lib" -lmuparser remove all other lines if it still fails, try to build muparser by MacPorts and restore changes in muparser.pri accordingly.
I don't think the problem is homebrew vs. macports.
This could be an answer: http://stackoverflow.com/questions/16972066/using-pkg-config-with-qt-creator-qmake-on-mac-osx |
Using:
MUPARSER_DIR = /usr/local INCLUDEPATH += "$${MUPARSER_DIR}/include" LIBS += -L"$${MUPARSER_DIR}/lib" -lmuparser worked, thanks. But it must be possible to use pkg-config with Qt on OSX, I have to investigate this. Also to use C++11, on OSX the QMAKE_MACOSX_DEPLOYMENT_TARGET = 10.6 is to old, you need to set it to a newer version. |
I'am trying to use Qt5.2, this is from the qconfig.pri:
QT_CONFIG += minimal-config small-config medium-config large-config full-config build_all debug_and_release no-pkg-config accessibility opengl shared qpa reduce_exports getaddrinfo ipv6ifname getifaddrs png freetype no-harfbuzz system-zlib nis cups iconv openssl rpath corewlan concurrent audio-backend debug release qt_framework So I think no-pkg-config is defined by default on OSX and pkg-config has to be explicit enabled. I managed to compile LibreCAD against homebrew Qt5.2 using the XCode 5.0 clang compiler. All problems solved, next is learning to work with LibreCAD. B.t.w. the binary Qt5 distribution from http://qt-project.org/ did not work because this is linked with libstdc++. Qt5 from homebrew is linked with libc++, which is the default with clang. Thanks. |
Running otool on LibreCDA from the contents of LibreCAD.app:
bash-3.2$ otool -L LibreCAD LibreCAD: /usr/local/lib/libmuparser.2.dylib (compatibility version 1.0.0, current version 1.0.0) /usr/local/opt/qt5/lib/QtHelp.framework/Versions/5/QtHelp (compatibility version 5.2.0, current version 5.2.0) /usr/local/opt/qt5/lib/QtWidgets.framework/Versions/5/QtWidgets (compatibility version 5.2.0, current version 5.2.0) /usr/local/opt/qt5/lib/QtGui.framework/Versions/5/QtGui (compatibility version 5.2.0, current version 5.2.0) /usr/local/opt/qt5/lib/QtCore.framework/Versions/5/QtCore (compatibility version 5.2.0, current version 5.2.0) /usr/local/opt/qt5/lib/QtPrintSupport.framework/Versions/5/QtPrintSupport (compatibility version 5.2.0, current version 5.2.0) /usr/local/opt/qt5/lib/QtSvg.framework/Versions/5/QtSvg (compatibility version 5.2.0, current version 5.2.0) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL (compatibility version 1.0.0, current version 1.0.0) /System/Library/Frameworks/AGL.framework/Versions/A/AGL (compatibility version 1.0.0, current version 1.0.0) /usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 120.0.0) /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1197.1.1) |
New user here and not a developer.
I'm installing on OSX 10.7. The Lion installer for v2.0.0 (the latest version for which a dmg installer is available) failed, so I tried installing from the source using macports. However, the muparser package can not be found. Below is an excerpt of the console output. Any ideas about what I should be doing next? I appreciate the help. Thanks. ... :info:configure Reading /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_cad_LibreCAD/LibreCAD/work/LibreCAD-2.0.3/librecad/src/src.pro :info:configure Project MESSAGE: We will be using CPP11 features :info:configure Project MESSAGE: Found Boost in /opt/local :info:configure Project MESSAGE: Using Boost includes from /opt/local/include :info:configure Project MESSAGE: qtAddLibrary: found framework QtHelp in directory /opt/local/Library/Frameworks :info:configure Project MESSAGE: qtAddLibrary: found framework QtSvg in directory /opt/local/Library/Frameworks :info:configure Project MESSAGE: qtAddLibrary: found framework QtSql in directory /opt/local/Library/Frameworks :info:configure Project MESSAGE: qtAddLibrary: found framework QtGui in directory /opt/local/Library/Frameworks :info:configure Project MESSAGE: qtAddLibrary: found framework QtCore in directory /opt/local/Library/Frameworks :info:configure Project ERROR: Package muparser not found :info:configure Command failed: cd "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_cad_LibreCAD/LibreCAD/work/LibreCAD-2.0.3" && /opt/local/bin/qmake -r PREFIX=/opt/local QMAKE_CC=/opt/local/bin/gcc-mp-4.8 QMAKE_CXX=/opt/local/bin/g++-mp-4.8 QMAKE_OBJC=/opt/local/bin/gcc-mp-4.8 CFLAGS="-Os -m64" CONFIG+="build_muparser" :info:configure Exit code: 2 :error:configure org.macports.configure for port LibreCAD returned: configure failure: command execution failed |
did you try to build from source following:
wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_LibreCAD-2.0_on_OS.2FX This muparser building issue was fixed for 2.0.4 release
