Build on OSX
11 messages Options
Build on OSX
Gertwin
New LibreCAD user (developer?) on OSX here.
I tried several (free) CAD applications to load my rather large dxf file (110mb. > 100000 entities).
LibreCAD was the only application which succeeded in doing so.
Next step for me is to to build LibreCAD from the source, but I am getting an error.
I installed boost with homebrew and muparser from the source.
Build output:
bash-3.2$ ./scripts/build-osx.sh
++ dirname ./scripts/build-osx.sh
+ SCRIPTPATH=./scripts
+ cd ./scripts/..
+ rm -rf LibreCAD.app
+ qmake librecad.pro -r
Reading /Users/gertwin/work/LibreCAD/LibreCAD.source/libraries/libraries.pro
 Reading /Users/gertwin/work/LibreCAD/LibreCAD.source/libraries/libdxfrw/libdxfrw.pro
Project MESSAGE: We will be using CPP11 features
 Reading /Users/gertwin/work/LibreCAD/LibreCAD.source/libraries/jwwlib/jwwlib.pro
Reading /Users/gertwin/work/LibreCAD/LibreCAD.source/librecad/librecad.pro
 Reading /Users/gertwin/work/LibreCAD/LibreCAD.source/librecad/src/src.pro
Project MESSAGE: Found Boost in /usr/local
Project MESSAGE: Using Boost includes from /usr/local/include
Project ERROR: Package muparser not found
I saw in muparser.pri the library is located with pkg-config.
In my case pkg-config can find it:
bash-3.2$ pkg-config --cflags --libs muparser
-I/usr/local/include -L/usr/local/lib -lmuparser
Any ideas why qmake does not find muparser?
Thanks,
Gertwin
Re: Build on OSX
Re: Build on OSX
In reply to this post by Gertwin
You may try to set in librecad/src/muparser.pri:
MUPARSER_DIR = /usr/local
INCLUDEPATH += "$${MUPARSER_DIR}/include"
LIBS += -L"$${MUPARSER_DIR}/lib" -lmuparser
remove all other lines
if it still fails, try to build muparser by MacPorts and restore changes in muparser.pri accordingly.
Re: Build on OSX
Gertwin
I don't think the problem is homebrew vs. macports.
This could be an answer: http://stackoverflow.com/questions/16972066/using-pkg-config-with-qt-creator-qmake-on-mac-osx
Re: Build on OSX
Gertwin
Using:
worked, thanks.
But it must be possible to use pkg-config with Qt on OSX, I have to investigate this.
Also to use C++11, on OSX the QMAKE_MACOSX_DEPLOYMENT_TARGET = 10.6 is to old, you need to set it to a newer version.
Re: Build on OSX
Re: Build on OSX
Gertwin
I'am trying to use Qt5.2, this is from the qconfig.pri:
QT_CONFIG += minimal-config small-config medium-config large-config full-config build_all debug_and_release no-pkg-config accessibility opengl shared qpa reduce_exports getaddrinfo ipv6ifname getifaddrs png freetype no-harfbuzz system-zlib nis cups iconv openssl rpath corewlan concurrent audio-backend debug release qt_framework
So I think no-pkg-config is defined by default on OSX and pkg-config has to be explicit enabled.
I managed to compile LibreCAD against homebrew Qt5.2 using the XCode 5.0 clang compiler.
All problems solved, next is learning to work with LibreCAD.
B.t.w. the binary Qt5 distribution from http://qt-project.org/ did not work because this is linked with libstdc++.
Qt5 from homebrew is linked with libc++, which is the default with clang.
Thanks.
Re: Build on OSX
Re: Build on OSX
Gertwin
Running otool on LibreCDA from the contents of LibreCAD.app:
bash-3.2$ otool -L LibreCAD
LibreCAD:
        /usr/local/lib/libmuparser.2.dylib (compatibility version 1.0.0, current version 1.0.0)
        /usr/local/opt/qt5/lib/QtHelp.framework/Versions/5/QtHelp (compatibility version 5.2.0, current version 5.2.0)
        /usr/local/opt/qt5/lib/QtWidgets.framework/Versions/5/QtWidgets (compatibility version 5.2.0, current version 5.2.0)
        /usr/local/opt/qt5/lib/QtGui.framework/Versions/5/QtGui (compatibility version 5.2.0, current version 5.2.0)
        /usr/local/opt/qt5/lib/QtCore.framework/Versions/5/QtCore (compatibility version 5.2.0, current version 5.2.0)
        /usr/local/opt/qt5/lib/QtPrintSupport.framework/Versions/5/QtPrintSupport (compatibility version 5.2.0, current version 5.2.0)
        /usr/local/opt/qt5/lib/QtSvg.framework/Versions/5/QtSvg (compatibility version 5.2.0, current version 5.2.0)
        /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL (compatibility version 1.0.0, current version 1.0.0)
        /System/Library/Frameworks/AGL.framework/Versions/A/AGL (compatibility version 1.0.0, current version 1.0.0)
        /usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 120.0.0)
        /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1197.1.1)
Re: Build on OSX
kshrid
New user here and not a developer.
I'm installing on OSX 10.7. The Lion installer for v2.0.0 (the latest version for which a dmg installer is available) failed, so I tried installing from the source using macports.
However, the muparser package can not be found. Below is an excerpt of the console output.
Any ideas about what I should be doing next? I appreciate the help.
Thanks.
:info:configure  Reading /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_cad_LibreCAD/LibreCAD/work/LibreCAD-2.0.3/librecad/src/src.pro
:info:configure Project MESSAGE: We will be using CPP11 features
:info:configure Project MESSAGE: Found Boost in /opt/local
:info:configure Project MESSAGE: Using Boost includes from /opt/local/include
:info:configure Project MESSAGE: qtAddLibrary: found framework QtHelp in directory /opt/local/Library/Frameworks
:info:configure Project MESSAGE: qtAddLibrary: found framework QtSvg in directory /opt/local/Library/Frameworks
:info:configure Project MESSAGE: qtAddLibrary: found framework QtSql in directory /opt/local/Library/Frameworks
:info:configure Project MESSAGE: qtAddLibrary: found framework QtGui in directory /opt/local/Library/Frameworks
:info:configure Project MESSAGE: qtAddLibrary: found framework QtCore in directory /opt/local/Library/Frameworks
:info:configure Project ERROR: Package muparser not found
:info:configure Command failed:  cd "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_cad_LibreCAD/LibreCAD/work/LibreCAD-2.0.3" && /opt/local/bin/qmake -r PREFIX=/opt/local QMAKE_CC=/opt/local/bin/gcc-mp-4.8 QMAKE_CXX=/opt/local/bin/g++-mp-4.8 QMAKE_OBJC=/opt/local/bin/gcc-mp-4.8 CFLAGS="-Os -m64" CONFIG+="build_muparser"
:info:configure Exit code: 2
:error:configure org.macports.configure for port LibreCAD returned: configure failure: command execution failed
Re: Build on OSX
did you try to build from source following:
wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_LibreCAD-2.0_on_OS.2FX
This muparser building issue was fixed for 2.0.4 release
Thanks.
