Can a 2D-LibreCAD Drawing exported to csv file?
sunggus
I would like to know whether it is possible to export a 2D LibreCAD drawing into a csv (comma separated value) file. I have tried to export it from File-->Export. There only available three options: Export as MarkerCAM SVG, Export as PDF, and Export as Image. No to csv. I am using LC 1.3. I will upgrade to newer version if in the newer version is available that tool. Or, is any way to do that?
Best regard,
Re: Can a 2D-LibreCAD Drawing exported to csv file?
I understand you want to export the drawing file rather than a picture of the drawing.
csv is a format for tabular data and is not a meaningful format for LibreCad. Use dxf, it is a text format file that can exchange drawings with other software.
