Can not open saved dxf file
39 messages Options
12
deanocarolyn
I am new to this program on a Mac Book pro Intel Core i5 running version 10.9
Running LibreCad
Version: master
SCM Revision: 2.0.0rc2-2-g8573398
Compiler: GNU GCC 4.7.3
Qt Version: 4.8.5
Compiled on: Aug 29 2013
After I save a file, I can not open it.  The program crashes.  The save as gives me several options and I have tried 2007.dxf, 2004.dxf, 2000.dxf, r14.dxf, r12.dxf    They all crash the program.  I have restarted the program between each try.  I have restarted the computer.  I have tried to select the files from the file menu recently opened and by going directly to the folder where the file is located.
Part of the Console Log is as follows:
Process:         LibreCAD [3590]
Path:            /Applications/LibreCAD.app/Contents/MacOS/LibreCAD
Identifier:      com.yourcompany.LibreCAD
Version:         ???
Code Type:       X86-64 (Native)
Parent Process:  launchd [158]
User ID:         501
Date/Time:       2013-10-21 23:00:55.683 -0700
OS Version:      Mac OS X 10.8.5 (12F45)
Report Version:  10
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000841f0f
VM Regions Near 0x841f0f:
    __TEXT                 0000000100000000-0000000100559000 [ 5476K] r-x/rwx SM=COW  /Applications/LibreCAD.app/Contents/MacOS/LibreCAD
Re: Can not open saved dxf file
can you uplaod a testcase dxf to show this bug?
deanocarolyn
Elevtor.dxf
test_load_libre.dxf
I uploaded a file called Elevtor.dxf and test_Load_libre.dxf
Elevtor has several objects but test_Load_libre only has a square.
on Windows I can open both files.
@dxli:
I've seen a problem in the DXF files. Look at the group codes 5, they are written with a 2 digit hex value. With a hex editor you can see, that these hex values are followed by 7 0x00 bytes before the line feed.
Think this is caused by the dxfRW::toHexStr(int n) in libdxfrw.cpp, lines 2662ff. The 2 hex digit plus the 7 zero bytes are the buffer size of the toHexStr() method. The method works different on OSX, because of the __APPLE__ define.
As I can see, the logic behind the code is OK, I would expect, that the processing of the buffer should stop at the first zero byte. This implies the assumption that it is a library issue on OSX.
As I can open the files without exception on Windows, this DXF writing issue must not be the cause for the crash on OSX. But it could be a similar bug on reading or processing the file.
Here are the files where I corrected the zero byte issue, can you please try to open them on OSX.
ElevtorWin.dxf
test_load_libreWin.dxf
The code for apple are diferent due a problem in mac ussing stringstream.
Using the apple part in windows produces the same mistake.
Added a patch in github solving this issue, but...
A file with code 5 like "31\0\0\0\0" only crashes in appple, not in win or linux then, another bug are present
Armin, thanks for the tip
deanocarolyn
In reply to this post by deanocarolyn
I tried both files that you sent back and both crashed LibreCad.  Thank you very much for sending the files.
Not sure what to do with the patch created by Ralllaz.  Is there a download for the Mac with the patch installed?
Thanks to both of you for addressing this problem.
deano
dxli has published new installer packages for OSX, you can find them on sourceforge.net:
https://sourceforge.net/projects/librecad/files/OSX/Testing%20Builds/
Please download and install the package for your OSX release to support troubleshooting.
Thanks,
deanocarolyn
Thanks, I have to be out for a couple of hours but will install when I get back and give it a shot.
deanocarolyn
No joy.  I installed the changed LibreCAD-Mavericks and tried to load one of the old files, tried to load the win files sent to me, and created a new file and tried to reload it.  The program crashed each time.
Is there anything you would like me to try or info to gather at this end that would help?
The about for the program shows:
Version: master
SCM Revision: 2.0.0rc2-83-ga73dede
Qt Version: 4.8.5
Compiled on: Nov 12 2013
Thanks,
deano
loading Elevtor.dxf on Mavericks works for me
deanocarolyn
That is interesting!
Just to cover some more bases.  I tried double clicking on the file.  It opens the LibreCAD program but does not display the saved file.  It opens with unnamed document 1.  I have then been trying to open the saved file on top of this document.  So I closed the unnamed document and then opened the saved file.  It opened once, but all attempts to open the same file or any of the others I have saved, do not open and crash the program. So trying a different path to open a file worked once.
I have run utilities on my system and have also cleaned all permissions.
Anything else I can do?
I added the full Console listing on one of the crashes.
deano
Console.rtf
deanocarolyn
I decided to try my wife's MacBook Air Intel Core 2 Duo running Mt Lion 10.85
Downloaded LibreCAD Mountain Lion and go the error message that the version is wrong for this machine.
I then downloaded Maverick and got the same message.
I then downloaded Lion and got the same message.
Any ideas?
I may take her machine up to Maverick and try again.  But will wait until tomorrow to see if anyone has any other ideas.
deano
deanocarolyn
Ok, I have solved part of the problem with a work around.
With the latest Mavericks LibreCad:
When I save to my desktop and then close the current LibreCAD work screen, I can go to file open and reopen the saved file.  If I close out of LibreCAD completely, the program will crash when I restart the program and try to open the saved file.
When I do a restart of LibreCAD, create a square and save the file to my desktop, I can reopen the newly saved file, I can open any of the other saved files that are on my desktop.  I can also open saved files in my Documents folder.
The bottom line here is, if I restart LibreCAD, I must first save a new drawing before I can open an old saved drawing.
deano
deanocarolyn
I should also mention.  I discovered this work around after installing Mavericks on my wife's Mac Air.  Her machine also crashed on saved files after a restart.  Once I noted that I needed to save a file first, before trying to open an older saved file, I went back to my MacBook pro and found it worked the same way.  Two Macs running Mavericks handle LibreCAD the same way.
Thanks,
Deano
I tested the procedure on Mavericks:
1, Start LibreCAD from the LibreCAD-Mavericks.dmg
2, draw a rectangle;
3, "Save As" to the drawing to a file, say, ~/a.dxf
4, Quit LibreCAD program by Menu: LibreCAD-> Quit LibreCAD (Command-Q)
5, start LibreCAD from LibreCAD-Mavericks.dmg
6, Open the file saved in step 3: ~/a.dxf
Results:
the file loads normally.
Please upload the crash report by OS/X.
Another thing to try: please build LibreCAD from source, and do the same test. We need to know whether this is a packaging issue.
To build LibreCAD from source, you will need macports to install Qt, boost, and MuParser.
http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_LibreCAD-2.0_on_OS.2FX
deanocarolyn
Thanks for the response.
I have a couple of friends that said they would help me with a build.  One is a Microsoft systems engineer and the other is an Amazon system engineer.  Both have experience with Macs.  But we can not find a common time until next week.
The below comes from launching the program, and then using File Open to open a previously saved file.  But if I save a file first in the same session, then I can open saved files.
Thanks,
deano
The current version I am running is:
Version: master
Qt Version: 4.8.5
And the Console crash info:
Process:         LibreCAD [4837]
Version:         0
Parent Process:  launchd [161]
Responsible:     LibreCAD [4837]
User ID:         501
Date/Time:       2013-11-15 13:40:22.325 -0800
OS Version:      Mac OS X 10.9 (13A603)
Report Version:  11
Anonymous UUID:  19F9B0BE-DFEB-570A-E5C1-8F52BDF0B71B
Sleep/Wake UUID: B962F641-305A-4A95-AE5C-06BC848F6E7C
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Dyld Error Message:
  Symbol not found: __ZNKSt5ctypeIcE13_M_widen_initEv
  Referenced from: /Applications/LibreCAD.app/Contents/MacOS/LibreCAD
  Expected in: /usr/lib/libstdc++.6.dylib
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   dyld                           0x00007fff6990a09d dyld_fatal_error + 1
1   dyld                           0x00007fff6990cdf6 dyld::fastBindLazySymbol(ImageLoader**, unsigned long) + 171
2   libdyld.dylib                 0x00007fff8ce8c31d dyld_stub_binder_ + 13
3   ???                           0x0000000103c71d78 0 + 4358348152
4   ???                           0x0000000000000016 0 + 22
5   libstdc++.6.dylib             0x00007fff897d9d60 std::basic_ifstream<char, std::char_traits<char> >::basic_ifstream(char const*, std::_Ios_Openmode) + 190
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib         0x00007fff864ae662 kevent64 + 10
1   libdispatch.dylib             0x00007fff8cc6443d _dispatch_mgr_invoke + 239
2   libdispatch.dylib             0x00007fff8cc64152 _dispatch_mgr_thread + 52
Thread 2:
0   libsystem_kernel.dylib         0x00007fff864a9a1a mach_msg_trap + 10
1   libsystem_kernel.dylib         0x00007fff864a8d18 mach_msg + 64
2   com.apple.CoreFoundation       0x00007fff8a710315 __CFRunLoopServiceMachPort + 181
3   com.apple.CoreFoundation       0x00007fff8a70f939 __CFRunLoopRun + 1161
4   com.apple.CoreFoundation       0x00007fff8a70f275 CFRunLoopRunSpecific + 309
5   com.apple.AppKit               0x00007fff8b65c1ce _NSEventThread + 144
6   libsystem_pthread.dylib       0x00007fff87116899 _pthread_body + 138
7   libsystem_pthread.dylib       0x00007fff8711672a _pthread_start + 137
8   libsystem_pthread.dylib       0x00007fff8711afc9 thread_start + 13
Thread 3:
0   libsystem_kernel.dylib         0x00007fff864ade6a __workq_kernreturn + 10
1   libsystem_pthread.dylib       0x00007fff87117f08 _pthread_wqthread + 330
2   libsystem_pthread.dylib       0x00007fff8711afb9 start_wqthread + 13
Thread 4:
Thread 5:: QFileInfoGatherer
0   libsystem_kernel.dylib         0x00007fff864ad716 __psynch_cvwait + 10
1   libsystem_pthread.dylib       0x00007fff87118c3b _pthread_cond_wait + 727
2   QtCore                         0x00000001041c1866 0x10419b000 + 157798
3   QtCore                         0x00000001041c16cd QWaitCondition::wait(QMutex*, unsigned long) + 109
4   QtGui                         0x00000001049cf091 0x1044e7000 + 5144721
5   QtCore                         0x00000001041c0238 0x10419b000 + 152120
Thread 6:: QKqueueFileSystemWatcherEngine
0   libsystem_kernel.dylib         0x00007fff864ae64a kevent + 10
1   QtCore                         0x000000010429e0b4 0x10419b000 + 1061044
2   QtCore                         0x00000001041c0238 0x10419b000 + 152120
3   libsystem_pthread.dylib       0x00007fff87116899 _pthread_body + 138
4   libsystem_pthread.dylib       0x00007fff8711672a _pthread_start + 137
5   libsystem_pthread.dylib       0x00007fff8711afc9 thread_start + 13
Thread 7:
Thread 8:
Thread 9:: CVDisplayLink
2   com.apple.CoreVideo           0x00007fff8c2c8a38 CVDisplayLink::runIOThread() + 656
3   com.apple.CoreVideo           0x00007fff8c2c878f startIOThread(void*) + 147
4   libsystem_pthread.dylib       0x00007fff87116899 _pthread_body + 138
5   libsystem_pthread.dylib       0x00007fff8711672a _pthread_start + 137
6   libsystem_pthread.dylib       0x00007fff8711afc9 thread_start + 13
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x00007fff6993edb0  rbx: 0x00006000003532a0  rcx: 0x0000000000000000  rdx: 0x0000000000000000
  rdi: 0x00007fff6993ef20  rsi: 0x0000000000000000  rbp: 0x00007fff5c4dc7c0  rsp: 0x00007fff5c4dc7a8
   r8: 0x00007fff69929b4c   r9: 0x0000000000000000  r10: 0x00007fff6992cce6  r11: 0x00007fff6993ef20
  r12: 0x00007fff74e24330  r13: 0x0000600000492610  r14: 0x00007fff6993ef20  r15: 0x00007fff5c4dc9cc
  rip: 0x00007fff6990a09d  rfl: 0x0000000000000246  cr2: 0x0000000105506000
Logical CPU:     0
Error Code:      0x00000000
Trap Number:     3
Binary Images:
       0x103721000 -        0x103c70fff +com.yourcompany.LibreCAD (0) <37E9A775-7098-3A63-B730-E56C61EFA9A6> /Applications/LibreCAD.app/Contents/MacOS/LibreCAD
       0x10400f000 -        0x104081fff +QtHelp (0) <E9D515A6-4D98-33EB-8E00-1405E108F617> /Applications/LibreCAD.app/Contents/Frameworks/QtHelp.framework/Versions/4/QtHelp
       0x1040a1000 -        0x104175ff7 +QtCLucene (0) <69F5309C-688A-3EF6-AF42-960C476AF4AB> /Applications/LibreCAD.app/Contents/Frameworks/QtCLucene.framework/Versions/4/QtCLucene
       0x10419b000 -        0x104436fff +QtCore (0) <52D6358D-43AC-3AE3-8B73-FDDE405636D0> /Applications/LibreCAD.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore
       0x10449f000 -        0x1044d1ff7 +QtSql (0) <C8DEDEE2-7BEA-3300-83A6-A97AC4E73BAE> /Applications/LibreCAD.app/Contents/Frameworks/QtSql.framework/Versions/4/QtSql
       0x1044e7000 -        0x104e16ff7 +QtGui (0) <8AEA68FB-1FF6-38C2-9999-C10EF7A27DDB> /Applications/LibreCAD.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui
       0x104fc0000 -        0x1050dcff7 +QtNetwork (0) <BEF4589B-C0D5-3AA7-AFAB-2904D88C2BE3> /Applications/LibreCAD.app/Contents/Frameworks/QtNetwork.framework/Versions/4/QtNetwork
       0x105118000 -        0x10515ffff +QtSvg (0) <E3DD2546-0892-3BE0-BE8A-EAE2793F98CD> /Applications/LibreCAD.app/Contents/Frameworks/QtSvg.framework/Versions/4/QtSvg
       0x10517b000 -        0x1051c2fff +libmuparser.0.dylib (0) <2DABFBAB-BED0-3B06-BEC0-5469408223F9> /Applications/LibreCAD.app/Contents/Frameworks/libmuparser.0.dylib
       0x1051d8000 -        0x1051e9fff +libz.1.dylib (0) <A9EB10A3-B238-3A9B-B23A-7FB5F5C9685E> /Applications/LibreCAD.app/Contents/Frameworks/libz.1.dylib
       0x1051ef000 -        0x105213fff +libpng15.15.dylib (0) <3255B49F-2B82-3978-8572-356D0CA00CF9> /Applications/LibreCAD.app/Contents/Frameworks/libpng15.15.dylib
       0x10521d000 -        0x105263ff7 +libssl.1.0.0.dylib (0) <274AF799-AB68-316F-8018-92A9FB9D725C> /Applications/LibreCAD.app/Contents/Frameworks/libssl.1.0.0.dylib
       0x105283000 -        0x1053c1fcf +libcrypto.1.0.0.dylib (0) <DFF00580-87A6-388A-9115-45DD8B63CDAC> /Applications/LibreCAD.app/Contents/Frameworks/libcrypto.1.0.0.dylib
       0x106d29000 -        0x106d29ffb +cl_kernels (???) <1E1625B5-DD6C-4D01-B2FA-28A2BBA601BE> cl_kernels
       0x106d6f000 -        0x106d8aff9  com.apple.security.csparser (3.0 - 55471) <0FA462BA-746F-3ACB-A90D-DCC7F280482B> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
       0x106d9e000 -        0x106e41ff7  ColorSyncDeprecated.dylib (426) <1EBD0729-A174-3EA5-B226-DE63C2E89D14> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
       0x1070cb000 -        0x1070d1ff7 +libqgif.dylib (0) <D0D8E9C9-8DA5-3947-AB43-112D192B0250> /Applications/LibreCAD.app/Contents/PlugIns/imageformats/libqgif.dylib
       0x1070d5000 -        0x1070dbff7 +libqico.dylib (0) <64D4D688-1A0F-3779-831A-6DFCC3251BA8> /Applications/LibreCAD.app/Contents/PlugIns/imageformats/libqico.dylib
       0x1070e0000 -        0x1070e5ff7 +libqjpeg.dylib (0) <ED7A10A3-270F-3164-8B08-0FF5C32DF05E> /Applications/LibreCAD.app/Contents/PlugIns/imageformats/libqjpeg.dylib
       0x1070ea000 -        0x10711ffff +libjpeg.9.dylib (0) <6F9B8E3B-15E5-3091-8562-3DD0BB85B63E> /Applications/LibreCAD.app/Contents/Frameworks/libjpeg.9.dylib
       0x107124000 -        0x107128fff +libqmng.dylib (0) <90B2C59D-EBA4-396C-A5ED-8D0FA7457C5C> /Applications/LibreCAD.app/Contents/PlugIns/imageformats/libqmng.dylib
       0x10712d000 -        0x10717dff7 +libmng.1.dylib (0) <33E945E2-5CB7-3AD4-BDFF-D4D0F59BFE7C> /Applications/LibreCAD.app/Contents/Frameworks/libmng.1.dylib
       0x107191000 -        0x107195ff7 +libqsvg.dylib (0) <58198182-9990-33AF-88CB-9BC12AEA7914> /Applications/LibreCAD.app/Contents/PlugIns/imageformats/libqsvg.dylib
       0x10aa87000 -        0x10aab6fff +liblcms.1.dylib (0) <8397726A-6075-3809-B482-E933F970803C> /Applications/LibreCAD.app/Contents/Frameworks/liblcms.1.dylib
       0x10aac0000 -        0x10ab00fff +QtXml (0) <C5C0C44A-29FB-302D-B26A-6BB169A85E16> /Applications/LibreCAD.app/Contents/Frameworks/QtXml.framework/Versions/4/QtXml
       0x10ab10000 -        0x10ab14fff +libqtga.dylib (0) <263C69A3-B3D0-3BB4-B135-2A7551524EB6> /Applications/LibreCAD.app/Contents/PlugIns/imageformats/libqtga.dylib
       0x10c0ec000 -        0x10c0f0fff +libalign.dylib (0) <C38CF9C9-CCE3-3909-B9A6-7291618C77A0> /Applications/LibreCAD.app/Contents/Resources/plugins/libalign.dylib
       0x10c0f5000 -        0x10c105ff7 +libasciifile.dylib (0) <5EE3F1C0-EF04-37F0-8969-8791D32DA42A> /Applications/LibreCAD.app/Contents/Resources/plugins/libasciifile.dylib
       0x10c114000 -        0x10c128fe7 +libimportshp.dylib (0) <3D1E1A7D-945F-381C-A734-AD27F7DBB57C> /Applications/LibreCAD.app/Contents/Resources/plugins/libimportshp.dylib
       0x10c134000 -        0x10c13fff7 +liblist.dylib (0) <7B97D13D-0512-3D57-BC9E-CD1A6863069E> /Applications/LibreCAD.app/Contents/Resources/plugins/liblist.dylib
       0x10c148000 -        0x10c14cfff +libsameprop.dylib (0) <7FD92381-DF67-3970-8510-9438B6FFDBCB> /Applications/LibreCAD.app/Contents/Resources/plugins/libsameprop.dylib
       0x10c151000 -        0x10c157ff7 +libsample.dylib (0) <1928D1B9-7940-3E3F-8483-772FD3CAA3D6> /Applications/LibreCAD.app/Contents/Resources/plugins/libsample.dylib
       0x10c629000 -        0x10c634fff  libGPUSupport.dylib (9.0.83) <AF15BF74-F9B3-35B9-8728-3B3A2EB6E432> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
       0x10d3b5000 -        0x10d49bfef  unorm8_bgra.dylib (2.3.58) <9FF943D1-4EF7-36CA-852D-B61C2E554713> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
       0x10d981000 -        0x10e0cbff7  libclh.dylib (4.0.3 - 4.0.3) <4A998D5D-A2C8-326F-AD0F-F0E2F60E920A> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/libclh.dylib
       0x10e8ac000 -        0x10e8adffa +cl_kernels (???) <B9097A90-8BB3-41AE-88AE-46A6EB28E94F> cl_kernels
       0x10e8ba000 -        0x10e8baff9 +cl_kernels (???) <8B69FED2-BEC5-430B-9994-BFC4463A00E7> cl_kernels
       0x10ea94000 -        0x10ea95ff4 +cl_kernels (???) <87311DFF-CB25-43F8-ABC9-991C9869AC48> cl_kernels
       0x10fb61000 -        0x10fc41ff7  unorm8_rgba.dylib (2.3.58) <DDD1AFEB-FD30-34D2-958A-823C3EFD649A> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
    0x123400000000 -     0x123400353ff7  com.apple.driver.AppleIntelHDGraphicsGLDriver (8.18.27 - 8.1.8) <208DD1B1-B1BA-3FBA-8C8B-B5A5E6CBB4D6> /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHDGraphicsGLDriver
    0x123440000000 -     0x123440867ff7  com.apple.GeForceTeslaGLDriver (8.18.27 - 8.1.8) <5B0E2B4A-D4E6-3C65-A8D5-87F24E79D432> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/GeForceTeslaGLDriver
    0x7fff69909000 -     0x7fff6993c817  dyld (239.3) <D1DFCF3F-0B0C-332A-BCC0-87A851B570FF> /usr/lib/dyld
    0x7fff841f3000 -     0x7fff84200ff0  libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib
    0x7fff8420b000 -     0x7fff84263ff7  com.apple.Symbolication (1.4 - 129) <16D42516-7B5E-357C-898A-FAA9EE7642B3> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff84264000 -     0x7fff842c3fff  com.apple.framework.CoreWLAN (4.0 - 400.45.1) <775F9444-8059-30A2-8058-7F7ACD68CCF1> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff842c4000 -     0x7fff842ecffb  libRIP.A.dylib (599.7) <6F528EE3-99F8-3871-BD60-1306495C27D5> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff842ed000 -     0x7fff84376ff7  libsystem_c.dylib (997.1.1) <61833FAA-7281-3FF9-937F-686B6F20427C> /usr/lib/system/libsystem_c.dylib
    0x7fff84377000 -     0x7fff84388ff7  com.apple.idsfoundation (10.0 - 1000) <0BC25100-092B-3C5A-8245-F7C963380785> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
    0x7fff84389000 -     0x7fff843a5fff  com.apple.frameworks.preferencepanes (16.0 - 16.0) <059E99D8-67C2-3B59-B5E7-850DD7A92D75> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
    0x7fff84ba0000 -     0x7fff84c13ffb  com.apple.securityfoundation (6.0 - 55122) <119D1C53-B292-3378-AEE1-A3B1FB02F43F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff84c14000 -     0x7fff84c16ff3  libsystem_configuration.dylib (596.12) <C4F633D9-94C8-35D9-BB2D-84C5122533C7> /usr/lib/system/libsystem_configuration.dylib
    0x7fff84c17000 -     0x7fff84c29ff7  com.apple.MultitouchSupport.framework (245.13 - 245.13) <D5E7416D-45AB-3690-86C6-CC4B5FCEA2D2> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff84e5a000 -     0x7fff84e83fff  com.apple.DictionaryServices (1.2 - 208) <A539A058-BA57-35EE-AA08-D0B0E835127D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff84e84000 -     0x7fff84e84fff  com.apple.AOSMigrate (1.0 - 1) <ABA8F3F2-BC96-3F89-AAF4-1AA459A0BCBD> /System/Library/PrivateFrameworks/AOSMigrate.framework/Versions/A/AOSMigrate
    0x7fff84e85000 -     0x7fff84e91ff7  com.apple.OpenDirectory (10.9 - 173.1.1) <6B78BD7B-5622-38E6-8FC6-86A117E3ACCA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff84ea2000 -     0x7fff84ea9ff3  libcopyfile.dylib (103) <5A881779-D0D6-3029-B371-E3021C2DDA5E> /usr/lib/system/libcopyfile.dylib
    0x7fff84eaa000 -     0x7fff84eb5ff7  com.apple.DirectoryService.Framework (10.9 - 173.1.1) <F8566D1F-450F-3571-911F-75C68E45919F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff85020000 -     0x7fff85190ff6  com.apple.CFNetwork (673.0.3 - 673.0.3) <42CFC3DB-35C8-3652-AF37-4BCC73D8BDEF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff85191000 -     0x7fff851a2ff7  libz.1.dylib (53) <42E0C8C6-CA38-3CA4-8619-D24ED5DD492E> /usr/lib/libz.1.dylib
    0x7fff851a3000 -     0x7fff851a4fff  libunc.dylib (28) <62682455-1862-36FE-8A04-7A6B91256438> /usr/lib/system/libunc.dylib
    0x7fff851a5000 -     0x7fff854a4fff  com.apple.Foundation (6.9 - 1056) <D608EDFD-9634-3573-9B7E-081C7D085F7A> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff854cc000 -     0x7fff8551dff3  com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <BF4C2FE3-8BC8-30D1-8347-2A7221268794> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff8551e000 -     0x7fff8557efff  com.apple.ISSupport (1.9.9 - 57) <E1E343D7-222C-3458-9D1F-FC600B7F1C50> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
    0x7fff855f1000 -     0x7fff855f9ff3  libCGCMS.A.dylib (599.7) <92AA4E85-7633-36E2-BAD0-7B1A2E48E75C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
    0x7fff855fa000 -     0x7fff85600ff7  libsystem_platform.dylib (24.1.4) <331BA4A5-55CE-3B95-99EB-44E0C89D7FB8> /usr/lib/system/libsystem_platform.dylib
    0x7fff85601000 -     0x7fff85602fff  liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib
    0x7fff8563d000 -     0x7fff85927fff  com.apple.CoreServices.CarbonCore (1077.13 - 1077.13) <21324540-8B84-3333-ADB8-D3D5181D4639> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff85928000 -     0x7fff85992ff7  com.apple.framework.IOKit (2.0.1 - 907.1.13) <C1E95F5C-B79B-31BE-9F2A-1B25163C1F16> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff859fc000 -     0x7fff85a07fff  libGL.dylib (9.0.83) <984A960A-C159-3AE5-8B40-E2B451F6C712> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff85a08000 -     0x7fff85a18fff  libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
    0x7fff85ca2000 -     0x7fff85ca4fff  libRadiance.dylib (1038) <55F99274-5074-3C73-BAC5-AF234E71CF38> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff85d02000 -     0x7fff85f7dff7  com.apple.RawCamera.bundle (4.09 - 711) <0040632D-09A9-32DE-98E8-BFA99F9F6526> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff85f7e000 -     0x7fff86228ffd  com.apple.HIToolbox (2.1 - 695) <C4DE35FF-D0AC-35C3-A7E6-F54CD153825C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff86229000 -     0x7fff86236fff  com.apple.Sharing (132.2 - 132.2) <F983394A-226D-3244-B511-FA51FDB6ADDA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff86237000 -     0x7fff86261ff7  libsandbox.1.dylib (278.10) <B4183FA8-F7E2-3301-8BF9-0EEFB793A5D5> /usr/lib/libsandbox.1.dylib
    0x7fff86262000 -     0x7fff8638efff  com.apple.MediaControlSender (1.9 - 190.4) <F5E934E1-D004-3C84-815A-961319F8C522> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
    0x7fff8638f000 -     0x7fff86396fff  com.apple.NetFS (6.0 - 4.0) <8E26C099-CE9D-3819-91A2-64EA929C6137> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff86397000 -     0x7fff863f2ffb  com.apple.AE (665.5 - 665.5) <BBA230F9-144C-3CAB-A77A-0621719244CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff863f5000 -     0x7fff86401ff7  com.apple.HelpData (2.1.4 - 90) <BEA1C549-40D3-35BF-9204-CB679FCB0648> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fff86442000 -     0x7fff86442ffd  com.apple.audio.units.AudioUnit (1.9 - 1.9) <6E89F3CB-CC41-3728-9F9A-FDFC151E8261> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff86443000 -     0x7fff86454ff7  libsystem_asl.dylib (217.1.4) <655FB343-52CF-3E2F-B14D-BEBF5AAEF94D> /usr/lib/system/libsystem_asl.dylib
    0x7fff86455000 -     0x7fff86497ff7  libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib
    0x7fff86498000 -     0x7fff864b4ff7  libsystem_kernel.dylib (2422.1.72) <D14913DB-47F1-3591-8DAF-D4B4EF5F8818> /usr/lib/system/libsystem_kernel.dylib
    0x7fff864b5000 -     0x7fff864e6fff  com.apple.MediaKit (15 - 709) <23E33409-5C39-3F93-9E73-2B0E9EE8883E> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff864e7000 -     0x7fff865cbfff  com.apple.coreui (2.1 - 231) <432DB40C-6B7E-39C8-9FB5-B95917930056> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff8665f000 -     0x7fff86673fff  com.apple.aps.framework (4.0 - 4.0) <F529A05B-FB03-397E-B06A-3A60B808FA11> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff868b1000 -     0x7fff86cfffff  com.apple.VideoToolbox (1.0 - 1273.29) <6E38291D-7A81-3033-AFB9-61ABD38B6371> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff86d00000 -     0x7fff86d6dfff  com.apple.SearchKit (1.4.0 - 1.4.0) <B9B8D510-A27E-36B0-93E9-17146D9E9045> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff86d6e000 -     0x7fff86d75ff7  liblaunch.dylib (842.1.4) <FCBF0A02-0B06-3F97-9248-5062A9DEB32C> /usr/lib/system/liblaunch.dylib
    0x7fff86d76000 -     0x7fff86d77ff7  libSystem.B.dylib (1197.1.1) <BFC0DC97-46C6-3BE0-9983-54A98734897A> /usr/lib/libSystem.B.dylib
    0x7fff86d78000 -     0x7fff86d8fffa  libAVFAudio.dylib (32.2) <52DA516B-DE79-322C-9E1B-2658019289D7> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
    0x7fff86d90000 -     0x7fff86d92ff7  libquarantine.dylib (71) <7A1A2BCB-C03D-3A25-BFA4-3E569B2D2C38> /usr/lib/system/libquarantine.dylib
    0x7fff86d93000 -     0x7fff86d95ffb  libutil.dylib (34) <DAC4A6CF-A1BB-3874-9569-A919316D30E8> /usr/lib/libutil.dylib
    0x7fff86d96000 -     0x7fff86db1ff7  libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib
    0x7fff86f0c000 -     0x7fff86f25ff7  com.apple.Kerberos (3.0 - 1) <F108AFEB-198A-3BAF-BCA5-9DFCE55EFF92> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff86f26000 -     0x7fff86f5afff  libssl.0.9.8.dylib (50) <B15F967C-B002-36C2-9621-3456D8509F50> /usr/lib/libssl.0.9.8.dylib
    0x7fff86f5b000 -     0x7fff87113ff3  libicucore.A.dylib (511.25) <3ED7B656-416E-3071-AEC8-E85C90232F78> /usr/lib/libicucore.A.dylib
    0x7fff87114000 -     0x7fff87114fff  com.apple.CoreServices (59 - 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff87115000 -     0x7fff8711cff7  libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib
    0x7fff87128000 -     0x7fff871f9ff1  com.apple.DiskImagesFramework (10.9 - 371.1) <D456ED08-4C1D-341F-BAB8-85E34A7275C5> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff871fa000 -     0x7fff87204fff  libcommonCrypto.dylib (60049) <8C4F0CA0-389C-3EDC-B155-E62DD2187E1D> /usr/lib/system/libcommonCrypto.dylib
    0x7fff8721c000 -     0x7fff872a4ff7  com.apple.CorePDF (4.0 - 4) <92D15ED1-D2E1-3ECB-93FF-42888219A99F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fff872cf000 -     0x7fff872d5fff  com.apple.AddressBook.ContactsFoundation (8.0 - 1365) <CFB1A744-8096-3FAB-B55E-2E6C410A0376> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
    0x7fff872d6000 -     0x7fff8732dfff  com.apple.ViewBridge (1.0 - 46) <C49FDC96-7087-3B2F-AEC3-039F7B2CB50C> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff8732e000 -     0x7fff8749cff7  libBLAS.dylib (1094.5) <DE93A590-5FA5-32A2-A16C-5D7D7361769F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff874a7000 -     0x7fff874f3ffe  com.apple.CoreMediaIO (401.0 - 4544) <44EBC0FE-DAD5-3711-96CB-05250F350A16> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fff874f4000 -     0x7fff8752eff3  com.apple.bom (12.0 - 192) <989690DB-B9CC-3DB5-89AE-B5D33EDC474E> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff8752f000 -     0x7fff87664ffa  com.apple.WebKit (9537 - 9537.71) <8A07478D-B2CA-3724-81E4-ADC10E1AD3EA> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x7fff87665000 -     0x7fff87665fff  com.apple.quartzframework (1.5 - 1.5) <3B2A72DB-39FC-3C5B-98BE-605F37777F37> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fff8766b000 -     0x7fff8766dff7  com.apple.securityhi (9.0 - 55005) <405E2BC6-2B6F-3B6B-B48E-2FD39214F052> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff8766e000 -     0x7fff876bffff  com.apple.QuickLookFramework (5.0 - 622.3) <AB6CCD09-ECDF-3F01-9C42-34B37DDCF12D> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff876c0000 -     0x7fff87705ff6  com.apple.HIServices (1.22 - 466) <21807AF8-3BC7-32BB-AB96-7C35CB59D7F6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff87706000 -     0x7fff8770afff  libsystem_stats.dylib (93.1.26) <B9E26A9E-FBBC-3938-B8B7-6CF7CA8C99AD> /usr/lib/system/libsystem_stats.dylib
    0x7fff8770b000 -     0x7fff877a8fff  com.apple.imcore (10.0 - 1000) <027E09B4-B4B6-3710-8806-B4CE41DF3242> /System/Library/PrivateFrameworks/IMCore.framework/Versions/A/IMCore
    0x7fff877ab000 -     0x7fff877f9fff  libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib
    0x7fff87854000 -     0x7fff886a0ff5  com.apple.WebCore (9537 - 9537.70) <7A90E9D3-4F26-3049-9C96-C6B8CB1395C8> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
    0x7fff886a1000 -     0x7fff8873cff7  com.apple.PDFKit (2.9 - 2.9) <AD968A31-6567-30A7-A699-154C88DB56D0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fff8873d000 -     0x7fff88748fff  libkxld.dylib (2422.1.72) <C88EF3E6-B31F-3E12-BE9B-562D912BA733> /usr/lib/system/libkxld.dylib
    0x7fff88939000 -     0x7fff88949ffb  libsasl2.2.dylib (170) <C8E25710-68B6-368A-BF3E-48EC7273177B> /usr/lib/libsasl2.2.dylib
    0x7fff8894a000 -     0x7fff88956ff3  com.apple.AppleFSCompression (56 - 1.0) <5652B0D0-EB08-381F-B23A-6DCF96991FB5> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff88957000 -     0x7fff8895cff7  libunwind.dylib (35.3) <78DCC358-2FC1-302E-B395-0155B47CB547> /usr/lib/system/libunwind.dylib
    0x7fff88966000 -     0x7fff88a28ff1  com.apple.CoreText (352.0 - 367.15) <E5C70FC8-C861-39B8-A491-595E5B55CFC8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff88a42000 -     0x7fff88a66fff  libxpc.dylib (300.1.17) <4554927A-9467-365C-91F1-5A116989DD7F> /usr/lib/system/libxpc.dylib
    0x7fff88a67000 -     0x7fff88d81ff7  com.apple.MediaToolbox (1.0 - 1273.29) <6260E68B-7E50-3D49-8C0A-7145614C13D8> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff88d82000 -     0x7fff88fe3ff7  com.apple.imageKit (2.5 - 770) <33BCF627-EB1A-3CC1-98AB-2324B6DFB329> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fff88fe4000 -     0x7fff890c3fff  libcrypto.0.9.8.dylib (50) <B95B9DBA-39D3-3EEF-AF43-44608B28894E> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff890cc000 -     0x7fff890d6fff  com.apple.AppSandbox (3.0 - 1) <55717299-8164-3D79-918F-BD64706735CF> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fff890d7000 -     0x7fff891dcfff  com.apple.ImageIO.framework (3.3.0 - 1038) <2C058216-C6D8-3380-A7EA-92A3F04520C1> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff891dd000 -     0x7fff891e6fff  com.apple.speech.synthesis.framework (4.6.2 - 4.6.2) <0AAE45F0-FC6E-36B6-A6A7-73E6950A74AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff891e7000 -     0x7fff8920effb  libsystem_info.dylib (449.1.3) <7D41A156-D285-3849-A2C3-C04ADE797D98> /usr/lib/system/libsystem_info.dylib
    0x7fff8920f000 -     0x7fff89457fff  com.apple.CoreData (107 - 481) <E5AFBA07-F73E-3B3F-9099-F51224EE8EAD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff89458000 -     0x7fff89459ff7  com.apple.print.framework.Print (9.0 - 260) <EE00FAE1-DA03-3EC2-8571-562518C46994> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff89469000 -     0x7fff89474ff7  com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff89475000 -     0x7fff89749fc7  com.apple.vImage (7.0 - 7.0) <D241DBFA-AC49-31E2-893D-EAAC31890C90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff8974a000 -     0x7fff89795fff  com.apple.ImageCaptureCore (5.0 - 5.0) <F529EDDC-E2F5-30CA-9938-AF23296B5C5B> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fff89796000 -     0x7fff8979efff  libsystem_dnssd.dylib (522.1.11) <270DCF6C-502D-389A-AA9F-DE4624A36FF7> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff8979f000 -     0x7fff8979fffd  libOpenScriptingUtil.dylib (157) <19F0E769-0989-3062-9AFB-8976E90E9759> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff897b4000 -     0x7fff897c3ff8  com.apple.LangAnalysis (1.7.0 - 1.7.0) <8FE131B6-1180-3892-98F5-C9C9B79072D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff897cb000 -     0x7fff89819ff9  libstdc++.6.dylib (60) <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
    0x7fff8981a000 -     0x7fff89c4dffb  com.apple.vision.FaceCore (3.0.0 - 3.0.0) <F42BFC9C-0B16-35EF-9A07-91B7FDAB7FC5> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff89c9e000 -     0x7fff89cc0fff  com.apple.framework.familycontrols (4.1 - 410) <4FDBCD10-CAA2-3A9C-99F2-06DCB8E81DEE> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x7fff89cc1000 -     0x7fff89cdcff7  libPng.dylib (1038) <EF781AF8-C2E6-3179-B8A1-A584783070F1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff89cdd000 -     0x7fff89cdfff7  com.apple.diagnosticlogcollection (10.0 - 1000) <5CA6D8A2-DEA6-33C3-91BC-F3B076C0500B> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
    0x7fff89ce0000 -     0x7fff89f23fff  com.apple.AddressBook.framework (8.0 - 1365) <816242B1-D45E-3B5D-BC98-BB23458D5367> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x7fff89f24000 -     0x7fff89f49ff7  com.apple.ChunkingLibrary (2.0 - 155.1) <B845DC7A-D1EA-31E2-967C-D1FE0C628036> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff89f4a000 -     0x7fff89f50ff7  com.apple.XPCService (2.0 - 1) <2CE632D7-FE57-36CF-91D4-C57D0F2E0BFE> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
    0x7fff89f51000 -     0x7fff89f58ff7  com.apple.phonenumbers (1.1.1 - 105) <767A63EB-244C-34F1-9FFA-D1A6BED60C31> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fff89f59000 -     0x7fff89f5cffa  libCGXType.A.dylib (599.7) <2FC9C2BC-B5C5-3C27-93F9-51C6C4512E9D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x7fff89f5d000 -     0x7fff89f8cff5  com.apple.GSS (4.0 - 2.0) <ED98D992-CC14-39F3-9ABC-8D7F986487CC> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff89f8d000 -     0x7fff89fa4fff  com.apple.CFOpenDirectory (10.9 - 173.1.1) <3FB4D5FE-860B-3BDE-BAE2-3531D919EF10> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff89fae000 -     0x7fff89fddfff  com.apple.DebugSymbols (106 - 106) <E1BDED08-523A-36F4-B2DA-9D5C712F0AC7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff8a098000 -     0x7fff8a0a2ff7  com.apple.CrashReporterSupport (10.9 - 538) <B487466B-3AA1-3854-A808-A61F049FA794> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff8a0a3000 -     0x7fff8a18aff7  libxml2.2.dylib (26) <A1DADD11-89E5-3DE4-8802-07186225967F> /usr/lib/libxml2.2.dylib
    0x7fff8a18b000 -     0x7fff8a279fff  libJP2.dylib (1038) <6C8179F5-8063-3ED6-A7C2-D5603DECDF28> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff8a27a000 -     0x7fff8a5f0ffa  com.apple.JavaScriptCore (9537 - 9537.65) <7E76880C-832E-385B-9591-ACCF57A68385> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff8a5f1000 -     0x7fff8a61dfff  com.apple.CoreServicesInternal (184.8 - 184.8) <707E05AE-DDA8-36FD-B0FF-7F15A061B46A> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff8a61e000 -     0x7fff8a64dfd2  libsystem_m.dylib (3047.16) <B7F0E2E4-2777-33FC-A787-D6430B630D54> /usr/lib/system/libsystem_m.dylib
    0x7fff8a64e000 -     0x7fff8a652ff7  libcache.dylib (62) <BDC1E65B-72A1-3DA3-A57C-B23159CAAD0B> /usr/lib/system/libcache.dylib
    0x7fff8a653000 -     0x7fff8a691ff7  libGLImage.dylib (9.0.83) <C08048A7-03CC-3E40-BCDC-7791D87AC8E4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff8a69f000 -     0x7fff8a884ff7  com.apple.CoreFoundation (6.9 - 855.11) <E22C6A1F-8996-349C-905E-96C3BBE07C2F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff8a885000 -     0x7fff8a888fff  com.apple.TCC (1.0 - 1) <32A075D9-47FD-3E71-95BC-BFB0D583F41C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff8a889000 -     0x7fff8a88cfff  com.apple.help (1.3.3 - 46) <AE763646-D07A-3F9A-ACD4-F5CBD734EE36> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff8a88d000 -     0x7fff8a896ff7  libcldcpuengine.dylib (2.3.58) <A2E1ED7B-FC7E-31F6-830A-FF917689766B> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff8a897000 -     0x7fff8a8beff7  com.apple.shortcut (2.6 - 2.6) <A62BC973-6782-3893-B014-EC6503AB7EAD> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fff8ac9b000 -     0x7fff8acc2ff7  libsystem_network.dylib (241.3) <8B1E1F1D-A5CC-3BAE-8B1E-ABC84337A364> /usr/lib/system/libsystem_network.dylib
    0x7fff8aceb000 -     0x7fff8ad4eff7  com.apple.SystemConfiguration (1.13 - 1.13) <F05F4149-981B-380B-8F50-51CE804BBB89> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff8ad62000 -     0x7fff8ad8cff7  libpcap.A.dylib (42) <91D3FF51-D6FE-3C05-98C9-1182E0EC3D58> /usr/lib/libpcap.A.dylib
    0x7fff8ad8d000 -     0x7fff8add6fff  com.apple.CoreMedia (1.0 - 1273.29) <4ACD30BA-E9FE-3842-A8B7-E3BD63747867> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff8add7000 -     0x7fff8addaffc  com.apple.IOSurface (91 - 91) <07CA8A59-1E32-3FB6-B506-18DAF58A8CE0> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff8ae02000 -     0x7fff8ae71ff1  com.apple.ApplicationServices.ATS (360 - 363.1) <88976B22-A9B8-3E7B-9AE6-0B8E09A968FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff8ae72000 -     0x7fff8ae72fff  com.apple.Accelerate (1.9 - Accelerate 1.9) <509BB27A-AE62-366D-86D8-0B06D217CF56> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff8ae73000 -     0x7fff8ae78fff  libmacho.dylib (845) <1D2910DF-C036-3A82-A3FD-44FF73B5FF9B> /usr/lib/system/libmacho.dylib
    0x7fff8ae7c000 -     0x7fff8ae7cff7  libkeymgr.dylib (28) <3AA8D85D-CF00-3BD3-A5A0-E28E1A32A6D8> /usr/lib/system/libkeymgr.dylib
    0x7fff8ae7d000 -     0x7fff8af6cfff  libFontParser.dylib (111.1) <835A8253-6AB9-3AAB-9CBF-171440DEC486> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff8af6d000 -     0x7fff8af76fff  com.apple.DisplayServicesFW (2.8 - 360.8.14) <816A9CED-1BC0-3C76-8103-1B9BE0F723BB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fff8af77000 -     0x7fff8af81ff7  libcsfde.dylib (380) <3A54B430-EC05-3DE9-86C3-00C1BEAC7F9B> /usr/lib/libcsfde.dylib
    0x7fff8af88000 -     0x7fff8af8afff  com.apple.Mangrove (1.0 - 1) <72F5CBC7-4E78-374E-98EA-C3700136904E> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fff8af8b000 -     0x7fff8af92fff  libcompiler_rt.dylib (35) <4CD916B2-1B17-362A-B403-EF24A1DAC141> /usr/lib/system/libcompiler_rt.dylib
    0x7fff8b09a000 -     0x7fff8b0a0fff  com.apple.AOSNotification (1.7.0 - 760.3) <7901B867-60F7-3645-BB3E-18C51A6FBCC6> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification
    0x7fff8b0df000 -     0x7fff8b3adff4  com.apple.CoreImage (9.0.54) <74BB8685-69A9-3A45-8DED-EA26BD39D710> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff8b3ae000 -     0x7fff8b3c6ff7  com.apple.GenerationalStorage (2.0 - 160.2) <79629AC7-896F-3302-8AC1-4939020F08C3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff8b3c7000 -     0x7fff8b3dfff7  com.apple.openscripting (1.4 - 157) <B3B037D7-1019-31E6-9D17-08E699AF3701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff8b3e0000 -     0x7fff8b409fff  GLRendererFloat (9.0.83) <1F1160A8-5047-3CEE-AC1E-D29520D0B367> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff8b40f000 -     0x7fff8b41dfff  com.apple.opengl (9.0.83 - 9.0.83) <AF467644-7B1D-327A-AC47-CECFCAF61990> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff8b498000 -     0x7fff8c00cff7  com.apple.AppKit (6.9 - 1265) <0E9FC8BF-DA3C-34C5-91CC-12BC922B5F01> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff8c00d000 -     0x7fff8c05fff7  com.apple.Suggestions (3.0 - 137.1) <B7E5B685-C6A4-35DB-BA0A-8DBA2BF4ADF6> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
    0x7fff8c0b4000 -     0x7fff8c0f5fff  com.apple.PerformanceAnalysis (1.47 - 47) <784ED7B8-FAE4-36CE-8C76-B7D300316C9F> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff8c0f6000 -     0x7fff8c15aff3  com.apple.datadetectorscore (5.0 - 354.0) <9ACF24B8-3268-3134-A5BC-D72C9371A195> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff8c15b000 -     0x7fff8c15eff7  com.apple.LoginUICore (3.0 - 3.0) <1ECBDA90-D6ED-3333-83EB-9C8232DFAD7C> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
    0x7fff8c1ce000 -     0x7fff8c1d6fff  libMatch.1.dylib (19) <021293AB-407D-309A-87F5-8E782F46753E> /usr/lib/libMatch.1.dylib
    0x7fff8c1d7000 -     0x7fff8c1fbff7  libJPEG.dylib (1038) <86F349A8-882D-3326-A0B0-63257F68B1A7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff8c1fc000 -     0x7fff8c204ff7  com.apple.AppleSRP (5.0 - 1) <ABC7F088-1FD5-3768-B9F3-847F355E90B3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff8c212000 -     0x7fff8c2c2ff7  libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff8c2c3000 -     0x7fff8c2c6fff  libCoreVMClient.dylib (58.1) <EBC36C69-C896-3C3D-8589-3E9023E7E56F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff8c2c7000 -     0x7fff8c2ecff7  com.apple.CoreVideo (1.8 - 117.2) <4674339E-26D0-35FA-9958-422832B39B12> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff8c2ed000 -     0x7fff8c2faff4  com.apple.Librarian (1.2 - 1) <F1A2744D-8536-32C7-8218-9972C6300DAE> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
    0x7fff8c2fb000 -     0x7fff8c2fcfff  com.apple.TrustEvaluationAgent (2.0 - 25) <334A82F4-4AE4-3719-A511-86D0B0723E2B> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff8c316000 -     0x7fff8c4c3f27  libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib
    0x7fff8c4c4000 -     0x7fff8c54ffff  libCoreStorage.dylib (380) <AE14C2F3-0EF1-3DCD-BF2B-A24D97D3B372> /usr/lib/libCoreStorage.dylib
    0x7fff8c550000 -     0x7fff8c589ff7  com.apple.QD (3.50 - 298) <C1F20764-DEF0-34CF-B3AB-AB5480D64E66> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff8c5d5000 -     0x7fff8c6a6ff7  com.apple.QuickLookUIFramework (5.0 - 622.3) <9741E66B-3978-35F6-8846-B6C528945611> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fff8c6a7000 -     0x7fff8c6a8ff7  libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib
    0x7fff8c6a9000 -     0x7fff8c6eeff7  libcurl.4.dylib (78) <A722B4F0-1F6C-3E16-9CB1-4C6ADC15221E> /usr/lib/libcurl.4.dylib
    0x7fff8c712000 -     0x7fff8c725ff7  com.apple.AppContainer (3.0 - 1) <A90C058D-46E8-3BAB-AF17-AF9C7C273069> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff8c726000 -     0x7fff8c76dff7  libcups.2.dylib (372) <348EED62-6C20-35D6-8EFB-E80943965100> /usr/lib/libcups.2.dylib
    0x7fff8c76e000 -     0x7fff8c787ff7  com.apple.Ubiquity (1.3 - 289) <C7F1B734-CE81-334D-BE41-8B20D95A1F9B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
    0x7fff8c8a5000 -     0x7fff8c9d5ff7  com.apple.desktopservices (1.8 - 1.8) <09DC9BB8-432F-3C7A-BB08-956A2DDFC2DE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff8c9d6000 -     0x7fff8c9d9fff  com.apple.AppleSystemInfo (3.0 - 3.0) <4D032152-AA40-350E-BB96-44BC55C5C69C> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff8c9dc000 -     0x7fff8ca29fff  com.apple.AppleVAFramework (5.0.27 - 5.0.27) <D01B7D87-4BDC-3E48-A79B-951D05075F9D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff8ca2a000 -     0x7fff8ca56ff7  com.apple.framework.SystemAdministration (1.0 - 1.0) <36C562FF-5D91-318C-A19C-6B4453FB78B9> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
    0x7fff8ca92000 -     0x7fff8cbf8fff  libGLProgrammability.dylib (9.0.83) <9C97E814-F674-30F8-8C2D-C45FC1E7D934> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff8cbf9000 -     0x7fff8cc5dff9  com.apple.Heimdal (4.0 - 2.0) <E7D20A4D-4674-37E1-A949-635FFF7C439A> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff8cc5e000 -     0x7fff8cc60ff7  com.apple.SecCodeWrapper (3.0 - 1) <F5107AD0-20CD-328C-8B2E-74CB6F3169F6> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff8cc61000 -     0x7fff8cc7bfff  libdispatch.dylib (339.1.9) <46878A5B-4248-3057-962C-6D4A235EEF31> /usr/lib/system/libdispatch.dylib
    0x7fff8cc7c000 -     0x7fff8cc7cfff  com.apple.Carbon (154 - 157) <45A9A40A-78FF-3EA0-8FAB-A4F81052FA55> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff8cc7d000 -     0x7fff8cc98ff7  libsystem_malloc.dylib (23.1.10) <FFE5C472-B23A-318A-85BF-77CDE61900D1> /usr/lib/system/libsystem_malloc.dylib
    0x7fff8cc99000 -     0x7fff8cc9dff7  libheimdal-asn1.dylib (323.12) <063A01C2-E547-39D9-BB42-4CC8E64ADE70> /usr/lib/libheimdal-asn1.dylib
    0x7fff8cc9e000 -     0x7fff8cd2aff7  com.apple.ink.framework (10.9 - 207) <8A50B893-AD03-3826-8555-A54FEAF08F47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff8cd2d000 -     0x7fff8cd62ffc  com.apple.LDAPFramework (2.4.28 - 194.5) <7E31A674-C6AB-33BE-BD5E-F5E3C6E22894> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff8cd63000 -     0x7fff8cdb1fff  com.apple.opencl (2.3.57 - 2.3.57) <FC03A80D-543A-3448-83FF-D399C3A240D9> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff8cdb2000 -     0x7fff8cdbcff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <2D27B498-BB9C-3D88-B05A-76908A8A26F3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff8cdbd000 -     0x7fff8cdbffff  com.apple.EFILogin (2.0 - 2) <C360E8AF-E9BB-3BBA-9DF0-57A92CEF00D4> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff8cdc0000 -     0x7fff8cdc0fff  com.apple.Cocoa (6.8 - 20) <E90E99D7-A425-3301-A025-D9E0CD11918E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff8cdc1000 -     0x7fff8ce8afff  com.apple.LaunchServices (572.23 - 572.23) <8D955BDE-2C4C-3DD4-B4D7-2D916174FE1D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff8ce8b000 -     0x7fff8ce8eff7  libdyld.dylib (239.3) <62F4D752-4089-31A8-8B73-B95A68893B3C> /usr/lib/system/libdyld.dylib
    0x7fff8ce8f000 -     0x7fff8ce98fff  com.apple.CommonAuth (4.0 - 2.0) <1D263127-5F27-3128-996D-7397660D0C6E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff8ce99000 -     0x7fff8ce9dfff  com.apple.CommonPanels (1.2.6 - 96) <6B434AFD-50F8-37C7-9A56-162C17E375B3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff8ce9e000 -     0x7fff8ce9fff7  libodfde.dylib (20) <C00A4EBA-44BC-3C53-BFD0-819B03FFD462> /usr/lib/libodfde.dylib
    0x7fff8cea0000 -     0x7fff8ceadff7  libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib
    0x7fff8ceae000 -     0x7fff8ced2fff  com.apple.quartzfilters (1.8.0 - 1.7.0) <39C08086-9866-372F-9420-81F5689149DF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fff8ced3000 -     0x7fff8cee9fff  com.apple.CoreMediaAuthoring (2.2 - 947) <B01FBACC-DDD5-30A8-BCCF-57CE24ABA329> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x7fff8cef7000 -     0x7fff8d14fff1  com.apple.security (7.0 - 55471) <233831C5-C457-3AD5-AFE7-E3E2DE6929C9> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff8d150000 -     0x7fff8d1a3fff  com.apple.ScalableUserInterface (1.0 - 1) <CF745298-7373-38D2-B3B1-727D5A569E48> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
    0x7fff8d1d9000 -     0x7fff8d1e1ffc  libGFXShared.dylib (9.0.83) <11A621C3-37A0-39CE-A69B-8739021BD79D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff8d1e2000 -     0x7fff8d1e6ff7  libGIF.dylib (1038) <C29B4323-1B9E-36B9-96C2-7CEDBAA124F0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff8d598000 -     0x7fff8d5eafff  libc++.1.dylib (120) <4F68DFC5-2077-39A8-A449-CAC5FDEE7BDE> /usr/lib/libc++.1.dylib
    0x7fff8d5eb000 -     0x7fff8d5f4ffb  libCGInterfaces.dylib (271) <68EFBEFE-7506-3235-99A2-5B69EDBFD7B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Resources/libCGInterfaces.dylib
    0x7fff8d5f5000 -     0x7fff8d5fbff7  libCGXCoreImage.A.dylib (599.7) <AC38090E-BA96-33C0-92F3-8EF6231582C4> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
    0x7fff8d5fc000 -     0x7fff8d5fefff  com.apple.marco (10.0 - 1000) <FC7EF8C7-5EDF-3720-BAEC-281F12A7A3F8> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
    0x7fff8d5ff000 -     0x7fff8d658fff  libTIFF.dylib (1038) <5CBFE0C2-9DD8-340B-BA63-A94CE2E476F2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff8d659000 -     0x7fff8d659fff  com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff8d65a000 -     0x7fff8d6d1fff  com.apple.CoreServices.OSServices (600.4 - 600.4) <36B2B009-C35E-3F21-824E-E0D00E7808C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff8d6d2000 -     0x7fff8d7c3ff9  libiconv.2.dylib (41) <BB44B115-AC32-3877-A0ED-AEC6232A4563> /usr/lib/libiconv.2.dylib
    0x7fff8e106000 -     0x7fff8e163fff  com.apple.imfoundation (10.0 - 1000) <122D84B9-871D-3885-9D8D-840CD529028F> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
    0x7fff8e1ee000 -     0x7fff8e37bff7  GLEngine (9.0.83) <26CCE609-D645-3945-A678-517ED5B65785> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff8e42f000 -     0x7fff8e45dff7  com.apple.securityinterface (9.0 - 55047) <0346D8A9-2CAA-38F3-A741-5FBA5E9F1E7C> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fff8e46b000 -     0x7fff8e555fff  libsqlite3.dylib (158) <00269BF9-43BE-39E0-9C85-24585B9923C8> /usr/lib/libsqlite3.dylib
    0x7fff8e556000 -     0x7fff8e585ff7  com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <404369C0-ED9F-3010-8D2F-BC55285F7808> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff8eaab000 -     0x7fff8eb34fff  com.apple.ColorSync (4.9.0 - 4.9.0) <B756B908-9AD1-3F5D-83F9-7A0B068387D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff8eb35000 -     0x7fff8ecd1ff7  com.apple.QuartzCore (1.8 - 332.0) <994D1E0A-64B6-398C-B9A2-C362F02DE943> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff8ecd2000 -     0x7fff8ee25ff7  com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <A0B7B007-9BD8-30E2-B644-47856DA29FEE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff8ee26000 -     0x7fff8ee86ff2  com.apple.CoreUtils (1.9 - 190.4) <CBB5B4DC-2801-32B3-A31C-8811CCF99873> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff8ee87000 -     0x7fff8efa9ff1  com.apple.avfoundation (2.0 - 651.12) <03E595B7-A559-3D4D-90E9-BCA603E3A39E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff8f015000 -     0x7fff8f032ff7  com.apple.framework.Apple80211 (9.0 - 900.47) <C897AFE6-DD73-387D-816A-67252A564207> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff8f033000 -     0x7fff8f038fff  com.apple.DiskArbitration (2.6 - 2.6) <F8A47F61-83D1-3F92-B7A8-A169E0D187C0> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff8f039000 -     0x7fff8f055fff  libresolv.9.dylib (54) <11C2C826-F1C6-39C6-B4E8-6E0C41D4FA95> /usr/lib/libresolv.9.dylib
    0x7fff8f0cd000 -     0x7fff8f0d1fff  libpam.2.dylib (20) <B93CE8F5-DAA8-30A1-B1F6-F890509513CB> /usr/lib/libpam.2.dylib
    0x7fff8f0d2000 -     0x7fff8f0e0fff  com.apple.CommerceCore (1.0 - 42) <ACC2CE3A-913A-39E0-8344-B76F8F694EF5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x7fff8f0e1000 -     0x7fff8f0fefff  com.apple.facetimeservices (10.0 - 1000) <9B4815BA-4305-381D-A178-F79E10B2C6E9> /System/Library/PrivateFrameworks/FTServices.framework/Versions/A/FTServices
    0x7fff8f0ff000 -     0x7fff8f623fff  com.apple.QuartzComposer (5.1 - 316) <B20E93C3-8517-3E5C-83B6-C312C839C5D0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fff8f624000 -     0x7fff8f671ff2  com.apple.print.framework.PrintCore (9.0 - 428) <8D8253E3-302F-3DB2-9C5C-572CB974E8B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff8f672000 -     0x7fff8f673fff  com.apple.AddressBook.ContactsData (8.0 - 1365) <61090508-4CC3-3F57-9B0C-D8527947D35D> /System/Library/PrivateFrameworks/ContactsData.framework/Versions/A/ContactsData
    0x7fff8f681000 -     0x7fff8f701fff  com.apple.CoreSymbolication (3.0 - 141) <B018335C-698B-3F87-AF1C-6115C4FA8954> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff8f763000 -     0x7fff9007f05f  com.apple.CoreGraphics (1.600.0 - 599.7) <7D0FD5A7-A061-39BA-8E00-723825D2C4DD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff90098000 -     0x7fff90098fff  com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <F8D0CC77-98AC-3B58-9FE6-0C25421827B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff90099000 -     0x7fff900e0fff  libFontRegistry.dylib (127) <A77A0480-AA5D-3CC8-8B68-69985CD546DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff900e1000 -     0x7fff900e6ff7  com.apple.MediaAccessibility (1.0 - 43) <D309D83D-5FAE-37A4-85ED-FFBDA8B66B82> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff901c5000 -     0x7fff901edffb  libxslt.1.dylib (13) <C9794936-633C-3F0C-9E71-30190B9B41C1> /usr/lib/libxslt.1.dylib
    0x7fff901ee000 -     0x7fff9027dff7  com.apple.Metadata (10.7.0 - 800.12) <04486C95-3E49-36C4-89B6-925E925BB417> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff90490000 -     0x7fff904dfff7  com.apple.framework.internetaccounts (2.1 - 210) <C77069C7-928C-315C-AA61-D90543901F20> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
    0x7fff904ed000 -     0x7fff9062dfff  com.apple.QTKit (7.7.3 - 2826) <7A110F61-D4DD-3C84-950D-E5F486DE5765> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fff9066d000 -     0x7fff9066eff7  libsystem_sandbox.dylib (278.10) <A47E7E11-3C76-318E-B67D-98972B86F094> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff9068e000 -     0x7fff906cafff  com.apple.ids (10.0 - 1000) <22502AAF-CC59-33EC-9ACF-106315206701> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
    0x7fff906cb000 -     0x7fff9070afff  libGLU.dylib (9.0.83) <8B457205-513B-3477-AE9C-3AD979D5FE11> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff9070b000 -     0x7fff9099cff7  com.apple.AOSKit (1.06 - 176) <35525B2F-B02F-31FD-A3B2-FD6AE6D32C11> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
    0x7fff9099d000 -     0x7fff909ceff7  libtidy.A.dylib (15.12) <BF757E3C-733A-3B6B-809A-A3949D46466E> /usr/lib/libtidy.A.dylib
    0x7fff90a11000 -     0x7fff90a3eff2  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <43A137C4-3E72-37DC-945F-92569C12AAD4> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff90a3f000 -     0x7fff90a48ff3  libsystem_notify.dylib (121) <52571EC3-6894-37E4-946E-064B021ED44E> /usr/lib/system/libsystem_notify.dylib
    0x7fff90abe000 -     0x7fff9102efff  com.apple.CoreAUC (6.22.08 - 6.22.08) <F306D552-2220-3160-88EA-C916193C5EFD> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff9102f000 -     0x7fff91030ff7  libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff912d3000 -     0x7fff91396ff7  com.apple.backup.framework (1.5 - 1.5) <92C8038F-CC00-3202-90D8-3C3AEC90986F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff91416000 -     0x7fff9143fff7  libc++abi.dylib (48) <8C16158F-CBF8-3BD7-BEF4-022704B2A326> /usr/lib/libc++abi.dylib
    0x7fff91440000 -     0x7fff91452fff  com.apple.ImageCapture (9.0 - 9.0) <BE0B65DA-3031-359B-8BBA-B9803D4ADBF4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff91453000 -     0x7fff914b9fff  com.apple.framework.CoreWiFi (2.0 - 200.21.1) <5491896D-78C5-30B6-96E9-D8DDECF3BE73> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff914ba000 -     0x7fff91815fff  com.apple.FinderKit (1.2 - 1.2) <B4B8F675-2F04-39BB-8B3C-A1E400DFDFD5> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
    0x7fff91817000 -     0x7fff91818ffb  libremovefile.dylib (33) <3543F917-928E-3DB2-A2F4-7AB73B4970EF> /usr/lib/system/libremovefile.dylib
    0x7fff91838000 -     0x7fff91840ff7  com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <98BBB3E4-6239-3EF1-90B2-84EA0D3B8D61> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff91841000 -     0x7fff91871fff  com.apple.IconServices (25 - 25.17) <4751127E-FBD5-3ED5-8510-08D4E4166EFE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff91872000 -     0x7fff918aaff7  com.apple.RemoteViewServices (2.0 - 94) <3F34D630-3DDB-3411-BC28-A56A9B55EBDA> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff918ab000 -     0x7fff918adfff  libCVMSPluginSupport.dylib (9.0.83) <E2AED858-6EEB-36C6-8C06-C3CF649A3CD5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff918ae000 -     0x7fff91c8fffe  libLAPACK.dylib (1094.5) <7E7A9B8D-1638-3914-BAE0-663B69865986> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff91d17000 -     0x7fff91de2fff  libvDSP.dylib (423.32) <3BF732BE-DDE0-38EB-8C54-E4E3C64F77A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff91de3000 -     0x7fff91e9bff7  com.apple.DiscRecording (8.0 - 8000.4.6) <CDAAAD04-A1D0-3C67-ABCC-EFC9E8D44E7E> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 92
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 4598324
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=276.9M resident=158.3M(57%) swapped_out_or_unallocated=118.6M(43%)
Writable regions: Total=234.3M written=74.8M(32%) resident=139.1M(59%) swapped_out=0K(0%) unallocated=95.2M(41%)
REGION TYPE                      VIRTUAL
CG backing stores                  8672K
CG image                            752K
CG raster data                       24K
CG shared images                    172K
CoreAnimation                      1752K
CoreAnimation (reserved)              8K        reserved VM address space (unallocated)
CoreGraphics                          8K
CoreImage                             8K
Foundation                            4K
IOKit                              38.5M
IOKit (reserved)                      4K        reserved VM address space (unallocated)
Kernel Alloc Once                     8K
MALLOC                            148.0M
MALLOC (admin)                       32K
Memory Tag 241                       92K
Memory Tag 242                       12K
Memory Tag 251                       20K
OpenCL                               40K
OpenGL GLSL                        1664K
STACK GUARD                        56.1M
Stack                              18.7M
VM_ALLOCATE                        17.4M
__DATA                             50.8M
__IMAGE                             528K
__LINKEDIT                         73.0M
__TEXT                            203.9M
__UNICODE                           544K
mapped file                        97.4M
shared memory                        68K
TOTAL                             717.8M
TOTAL, minus reserved VM space    717.8M
Re: Can not open saved dxf file
deanocarolyn
In reply to this post by deanocarolyn
Just an update on this problem.
I can open from the menu saved dxf file now without crashing the program.  Have not changed anything on the LibreCad side but Mavericks has updated.
I did try to load the source code to see if I could find the problem.  But I could not get qt4 or qt5 to install.
you can use macports to install qt4:
sudo port install qt4-mac
I tried to get qt5 from qt mac installer, but I mainly use qt4-mac from macports
deanocarolyn
Thanks for the reply, I tried the exact line yesterday and it failed but after your note, I did a cold reboot and it worked fine.  Now I need to find some time to load the source and see what else I find.
Thanks again
deanocarolyn
I tried to compile the source and got:
1 error generated.
make[2]: *** [../../generated/librecad/obj/rs_painter.o] Error 1
make[1]: *** [sub-src-make_default] Error 2
make: *** [sub-librecad-make_default-ordered] Error 2
looked back thru all the build items and noticed that gcc46 failed.
Error: Processing of port gcc46 failed
did not find anything on web to help install gcc46 on Mavericks
12
