Dimensions & Annotations not showing up in Windows version of LibreCAD
timschoenfelder
I created a block for my building lot.  I then added dimensions as described in the following youtube tutorial:
How to Draw a 45' x 20' Floor Plan in LibreCAD with Exact Measurements
https://www.youtube.com/watch?v=NfMSJHsvDbQ
Essentially used dimensions aligned, then clicked the top side of the block and pulled away and clicked again.  Similar for the side.  I verified this with the manual also.
However, all I see for dimensions are a blank block.
In addition my annotations are blank as well.
The fonts in C:\Program Files (x86)\LibreCAD\resources\fonts are what I see in the dimensions & text options.  I tried different fonts for both dimensions & MText.
Ideas?
DimensionPreferences
From about:
Version: 2.2.0.2
Compiler: GNU GCC 13.1.0
Compiled on: Jul 29 2023
Qt Version: 5.12.11
Boost Version: 1.75.0
System: Windows 10 (10.0)
Re: Dimensions & Annotations not showing up in Windows version of LibreCAD
timschoenfelder
Overlooked posting a sample of the drawing:
timschoenfelder
In reply to this post by timschoenfelder
timschoenfelder
nm, I found that restarting after pasting the windows fonts path into the fonts path like
LibreCAD dimension text not showing up #45270
https://github.com/void-linux/void-packages/issues/45270
Fixed it.
