Hatching
8 messages Options
Hatching
mdanbury
I'm a beginner users but can't get hatching to work.  I followed all the steps in the user manual but after clicking on the area to be hatched nothing else appears, I was expecting to see the available hatches to select.  I have looked in the Application preferences and nothing is in the "paths" for hatching (or any other option for that matter) so to me the issue could be that there aren't any hatching options for LibreCAD to display.  I've looked in the program files directory and can't find any files that have names like those shown in the user manual section on hatching.
So where do you get the hatching files from and where does one put them?
Any help gratefully received.
Re: Hatching
Can you share some screenshot to show the problem of missing hatching patterns in selection?
if you installed by standard installers (on windows, I suppose), pattern dxf files should be there.
Even if they are missing, please try to hatch by solid Area, as a test.
RE: Hatching
mdanbury
Below is screenshot with annotation.  How do you hatch by solid area?
Regards
Mike
Mike Danbury
Director
a4Marketing Limited
Hurcroft, Ashbrook Lane
St. Ippolyts, Herts. SG4 7PB
Mob +44(0) 7717 436 250
Office +44 (0) 1462 440 692
Registered No: 4066872
Registered Office: 69 Knowle Piece Hitchin SG4 0TY
Sent: 18 March 2015 12:54
To: mdanbury
Subject: Re: Hatching
http://forum.librecad.org/Hatching-tp5711216p5711217.html
To unsubscribe from Hatching, click here.
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2015.0.5751 / Virus Database: 4306/9313 - Release Date: 03/16/15
RE: Hatching
mdanbury
Sorry forgot to mention.  Installed under Windows XP.  I've found the files under C:\Program Files\LibreCAD\resources\patterns and put this path into the hatching line of the application preference box but its made no difference
Regards
Mike
Mike Danbury
Director
a4Marketing Limited
To: mdanbury
RE: Hatching
In reply to this post by mdanbury
you need to select entities to hatch (the 4 lines of the square)
followed by clicking the right pointing arrow on the left toolbar area.
RE: Hatching
mdanbury
OK, I now get the menu to choose hatch pattern, however whichever pattern I select nothing happens on screen, nothing happens in the preview box either.  The command line indicates that the hatch worked by showing:
Hatch created successfully
Total hatch area = 3500
Any ideas?
Thanks for your help.
Regards
Mike
Mike Danbury
Director
a4Marketing Limited
Sent: 18 March 2015 17:48
To: mdanbury
Subject: RE: Hatching
http://forum.librecad.org/Hatching-tp5711216p5711220.html
Version: 2015.0.5751 / Virus Database: 4311/9329 - Release Date: 03/18/15
RE: Hatching
First, double checkout on "Draft Mode". No hatch, image, or text are shown in draft mode.
http://forum.librecad.org/only-empty-boxes-frames-are-shown-for-image-text-no-line-thickness-td5706737.html
You may also try "solid fill"
mdanbury wrote
Any ideas?
Regards
Mike
Mike Danbury
Director
a4Marketing Limited
[hidden email]
  _____
To: mdanbury
  _____
below:
<http://forum.librecad.org/template/NamlServlet.jtp?macro=unsubscribe_by_cod
e&node=5711216&code=bWlrZUBhNG1hcmtldGluZy5jb218NTcxMTIxNnwtODYyMjE1MzI4>
here.
<http://forum.librecad.org/template/NamlServlet.jtp?macro=macro_viewer&id=in
stant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-
nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamesp
ace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21na
bble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
  _____
RE: Hatching
mdanbury
Clicking the Draft option fixed the problem.  Many thanks for your help.
Kind regards
Mike
Mike Danbury
Director
a4Marketing Limited
Sent: 18 March 2015 23:51
To: mdanbury
mdanbury wrote
Any ideas?
Regards
Mike
Mike Danbury
Director
a4Marketing Limited
[hidden email]
  _____
To: mdanbury
  _____
below:
here.
  _____
http://forum.librecad.org/Hatching-tp5711216p5711228.html
