I myself haven't played around with blocks yet, so I hesitated to answer. As you might have found out yourself meanwhile, in the block list there is a feature 'save the active block to a file'. Then in a new drawing in 'file - import - block' select that file where ever you have put it. I have tried it out now, you will have to expect some trouble like lost hatches, wrong scaling and maybe others. Scaling can be fixed after insertion by 'scale', the scaling factor during insertion process didn't work for me. Also if units are not in mm or different in source and target problems are likely.
Good luck.
