New user, crash on startup (Mac), advice?
11 messages Options
BobCollins
Re: New user, crash on startup (Mac), advice?
Hi Bob,
Please upload a crash report to help us resolve this issue, and any crashing and potential data loss issues should be fixed at the highest priority.
We do know our OS/X packaging is not stable enough, as we currently have no OS/X developer on board. Help is needed.
One work around for this packaging issue is to build LibreCAD from source, because the crashes are caused by packaging only.
BobCollins wrote
I downloaded v2.0.2 for OS X Lion, clicked on it, and it crashes immediately. This is consistent behavior.
I am using a MBP with OS X 10.7.5
Questions:
1) Why are there different versions of LibreCAD for different versions of OS X?
2) As this release is broken for me, what is the recommended next step? Should I try an older version? If so, which one?
Thanks,
Bob
In reply to this post by BobCollins
another thought:
we would like to have LibreCAD be included in MacPorts. Again, we need help here.
BobCollins
can you enable debugging, or run LibreCAD in gdb to provide debugging info
jp0678
Same Subj. Problem:
MacPro v1.1, OS X 10.7.5, 16 Gb RAM
Process: launchd [1428]
Path: /Applications/LibreCAD.app/Contents/MacOS/LibreCAD
Identifier: com.yourcompany.LibreCAD
Version: ??? (???)
Code Type: X86-64 (Native)
Parent Process: launchd [290]
Date/Time: 2014-01-27 09:32:16.624 -0500
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Interval Since Last Report: 36023 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: A215F3C5-F255-4BCF-926C-997F17972E13
Crashed Thread: Unknown
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00007fff5fc01028
Backtrace not available
Unknown thread crashed with X86 Thread State (64-bit):
rax: 0x0000000000000055 rbx: 0x0000000000000000 rcx: 0x0000000000000000 rdx:
0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x0000000000000000 rbp: 0x0000000000000000 rsp:
0x0000000000000000
r8: 0x0000000000000000 r9: 0x0000000000000000 r10: 0x0000000000000000 r11:
0x0000000000000000
r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x0000000000000000 r15:
0x0000000000000000
rip: 0x00007fff5fc01028 rfl: 0x0000000000010203 cr2: 0x00007fff5fc01028
Logical CPU: 1
Binary images description not available
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 1411
thread_create: 5
thread_set_state: 0
Model: MacPro1,1, BootROM MP11.005C.B08, 4 processors, Dual-Core Intel Xeon, 2.66 GHz, 16
GB, SMC 1.7f10
Graphics: NVIDIA GeForce 7300 GT, NVIDIA GeForce 7300 GT, PCIe, 256 MB
Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MB
Memory Module: DIMM Riser A/DIMM 1, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x05F7,
0x000000003732353642363145353636374600
Memory Module: DIMM Riser A/DIMM 2, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x05F7,
Memory Module: DIMM Riser B/DIMM 1, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x05F7,
Memory Module: DIMM Riser B/DIMM 2, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x05F7,
Memory Module: DIMM Riser A/DIMM 3, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x7F61,
0x000000000000000000000000000000000000
Memory Module: DIMM Riser A/DIMM 4, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x7F61,
Memory Module: DIMM Riser B/DIMM 3, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x7F61,
Memory Module: DIMM Riser B/DIMM 4, 2 GB, DDR2 FB-DIMM, 667 MHz, 0x7F61,
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x87), Broadcom BCM43xx 1.0
(5.10.131.36.15)
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce 7300 GT, sppci_displaycontroller, Slot-4
PCI Card: ATI Radeon HD 5770, sppci_displaycontroller, Slot-1
PCI Card: ATI Radeon HD 5770, ATY,HoolockParent, Slot-1
Serial ATA Device: WDC WD1003FBYX-01Y7B1, 1 TB
Serial ATA Device: WDC WD5003ABYX-01WERA1, 500.11 GB
Serial ATA Device: SAMSUNG HE753LJ, 750.16 GB
Serial ATA Device: WDC WD2500KS-00MJB0, 250.06 GB
Parallel ATA Device: PIONEER DVD-RW DVR-111D
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd400000 / 3
USB Device: Apple Optical USB Mouse, apple_vendor_id, 0x0304, 0xfd410000 / 5
USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfd420000 / 4
USB Device: hub_device, 0x0409 (NEC Corporation), 0x005a, 0xfd300000 / 2
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8206, 0x5d200000 / 2
FireWire Device: built-in_hub, 800mbit_speed
from Console App:
1/27/14 9:32:16.958 AM com.apple.launchd.peruser.503: ([0x0-
0x47047].com.yourcompany.LibreCAD[1428]) Job appears to have crashed: Segmentation fault: 11
Previous crash:
Process: launchd [4755]
Version: ??? (???)
Parent Process: launchd [4304]
Date/Time: 2014-01-25 22:22:04.779 -0500
Report Version: 9
Interval Since Last Report: 2311896 sec
0x0000000000000000
0x0000000000000000
0x0000000000000000
0x0000000000000000
Logical CPU: 3
task_for_pid: 1
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 13941
thread_create: 4
thread_set_state: 0
System Profile:
GB, SMC 1.7f10
(5.10.131.36.15)
Version: ??? (???)
Report Version: 9
0x0000000000000000
0x0000000000000000
0x0000000000000000
0x0000000000000000
Logical CPU: 1
task_for_pid: 1
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 1411
thread_create: 5
thread_set_state: 0
jp0678
Attempted to build (I am not a programming person, but  can follow directions):
MacPorts 2.2.1 installed
Qt 5.2 installed
gcc 4.8.2 installed
Attempt to install libreCAD failed --Partial terminal printout follows next under:
Available versions for gcc:
        gcc42
        llvm-gcc42
        mp-gcc48
        none (active)
MacPro1-2:~ jmeap$ sudo port install librecad
--->  Computing dependencies for pkgconfig
--->  Fetching archive for pkgconfig
Warning: Your DNS servers incorrectly claim to know the address of nonexistent hosts. This may cause checksum mismatches for some ports.
--->  Attempting to fetch pkgconfig-0.28_0+universal.darwin_11.i386-x86_64.tbz2 from http://packages.macports.org/pkgconfig
--->  Attempting to fetch pkgconfig-0.28_0+universal.darwin_11.i386-x86_64.tbz2.rmd160 from http://packages.macports.org/pkgconfig
--->  Installing pkgconfig @0.28_0+universal
--->  Cleaning pkgconfig
--->  Deactivating pkgconfig @0.25_2+universal
--->  Activating pkgconfig @0.28_0+universal
--->  Computing dependencies for LibreCAD
--->  Fetching archive for LibreCAD
--->  Attempting to fetch LibreCAD-2.0.2_0.darwin_11.x86_64.tbz2 from http://packages.macports.org/LibreCAD
--->  Attempting to fetch LibreCAD-2.0.2_0.darwin_11.x86_64.tbz2 from http://mse.uk.packages.macports.org/sites/packages.macports.org/LibreCAD
--->  Attempting to fetch LibreCAD-2.0.2_0.darwin_11.x86_64.tbz2 from http://lil.fr.packages.macports.org/LibreCAD
--->  Fetching distfiles for LibreCAD
Error: LibreCAD 2.x only works with OS X 10.9 Mavericks or later.
Error: You might want to try a 1.x series release instead.
Error: org.macports.fetch for port LibreCAD returned: incompatible OS X version
Please see the log file for port LibreCAD for details:
    /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_cad_LibreCAD/LibreCAD/main.log
To report a bug, follow the instructions in the guide:
    http://guide.macports.org/#project.tickets
Error: Processing of port librecad failed
MacPro1-2:~ jmeap$
If we can figure out a way to use gcc >= 4.6 instead of clang
we may have to modify the gcc CXXFLAGS from -std=c++11 to -std=c++0x
R. van Twisk wrote
JP,
We have disabled building of LibreCAD 2.0.x branch for older versions of OS-X due to LibreCAD needing C++11 which is not (easely) available for OSX versions < 10.9
Dli,
we might want to discuss this situation and see what we can do about it.
