This issue is a serious bug to me. Definitely, not intuitive behavior to most end users, and potentially data loss, due to misunderstanding.
I have added a fix to both 2.2.2 and 2.2.1 branches:
Renamed Close to Discard;
Also closing/cancel to cancel the closing and keep the drawing window open;
Save should also update the recent files, so can be easily found later.
usuario wrote
I am using a translator.
Thank you very much for your work on LibreCAD, hopefully version 2.2.1 will be very stable, if you can please remember to check the following:
In the message box, the cancel button [1] and the close button [2] on the top right (window control buttons) close the tab, even if there is an unsaved drawing.
Is this the desired behavior?
https://forum.librecad.org/LibreCAD-unexpected-behavior-tp5725111.htmlBest regards.
