Random Lines Inserted
JDelgado0311
Sorry to be such a pain as I just posted a question.  I added a Circle and some text to the a layer (Layout New) and toggled its visibility. Then, random vertical and Horizontal lines appeared on the layer.  I closed the files and reopened it but the lines remain.
I don't think that I did something the add the lines.  So, this may be a bug.
Thanks again - Jesse
####FamRoom_Electrical.dxf
Re: Random Lines Inserted
believe it or not. It's a feature by design, instead of a bug.
Have a look at http://forum.librecad.org/Need-an-icon-for-quot-Help-Layer-quot-in-the-layer-widget-td5710864.html
If you want to hide a layer, toggle the "Visible" sign. Our developer Armin is working to have a way to avoid this type confusion in the future.
In reply to this post by JDelgado0311
Use the printer icon in the Layer List. It is disabled for layer "Layout New".
If printing is disabled for a layer, all straight lines become infinite. This feature is called construction layer.
Enable printing for the layer and the infinite line extensions disappear.
JDelgado0311
Thank you one and all!
I think it's a hardware problem - There's a nut loose behind the mouse!
