I just downloaded and installed v2.1.3 and the Snap Selection toollbar is missing. I checked the Widgets/Toolbars and Snap Selection is checked, however it is not visible. Is this a bug or is there some way to gain access to the tool?
It seems you have Snap selections twice in the Toolbars dropdown menu, the second in a different language? That's odd. What if you untick the second one? Have you played around with the menu creator and maybe accidentally removed the Snap icons? A bad download? I would uninstall LibreCAD and reinstall a fresh download. If you are on Windows you could also try the portable version from from portableapps.com. You can install it in parallel to a normal install, this would avoid problems from some faulty registry settings.
I had tried to create a new snap selection tool but that didn't work either.
I downloaded and installed the portable version an everything looks correct.
I'll give it a try by doing some drawings to see, but everything is where it should be.'
Thanks for the tip.
