Tutorial LibreCAD - Beginner Level
37 messages Options
12
mancad
Download an install librecad. You can use libreCAD in linux, windows, and mac.
Librecad untuk Indonesia..
Work With Layer - LibreCAD
mancad
Work with layer - librecad
Drawing Lines - LibreCAD
mancad
In reply to this post by mancad
How to drawing lines - librecad.
Setting Dimensions - LibreCAD
mancad
Setting dimension - librecad
Drawing Rectangles
mancad
Drawing rectangles on libreCAD
Draw Circles - libreCAD Tutorial
mancad
1. Center point at first click - based on radius value.
2. Using two points - based on diameter value.
Re: Draw Circles - libreCAD Tutorial
mancad
Write text on librecad - Tutorial
To Hatch or Fill an Object or an Area - LibreCAD
mancad
Hatch
Ho to hatch a half of a circle - LIBRECAD Tutorial
mancad
In this video you will show how to hatch a half of a circle
Snap to end point, snap middle, and snap center
mancad
Use snap to control precision of your drawing object.
How To Move/Copy an Object - Librecad Tutorial
mancad
Move/Copy an object in Librecad.
1. Block the object
2. Select Move/Copy tool on the left sidebar
3. Click on the reference point
4. Specify the target and enter
5. Move the object choose "delete original" or
6. Copy the object choose "keep original
How to rotate an object - Librecad Tutorial
mancad
How to rotate an object :
1. Select the object.
2. Click rotate tool.
3. Click at the first reference point
4. Click at second reference point
5. Click at the specify point where you want to place the object
6. Choose "Delete Original" to rotate without copy the original object
7. Corret the angel you want to rotate the object
8. Click ok
Scale or Resize an object - Librecad Tutorial
mancad
How to resize or scale an object :
1. Block the object
2. Select scale tool
3. Click at reference point
4. Fill the scale number
5. Select Delete Original
6. Click Ok
Mirror an object - Librecad Tutorial
mancad
Mirror an object in librecad :
1. Block/select the object
2. Click Mirror tool
3. Click on first mirror line
4. Click on second mirror line
5. Select "keep original" if you want to mirror and copy the object
6. Select "delete original" if you want to mirror and move the object
7. Click ok
How to Change Workspace Background - LIBRECAD Tutorial - Librecad Tutorial
mancad
Change workspace background :
1. Go to options
2. Aplication preferences
3. Change the background color
4. Click ok
Trim and Trim Two - LIBRECAD TUTORIAL
mancad
Trim use to cut the line or multiple lines.
Trim two use to cut two lines.
How to Fillet in Librecad
mancad
1. Select fillet command
2. Specify the radius
3. Click at the first line
4. Click at the second
How To Extend Line With Lengthen or Trim Commands, Librecad Tutorial
mancad
Extend Line Using Lengthen Command :
1. Select lengthen command
2. Specify the length / distance
3. Click on the line you want to extend
Extend Line Using Trim Command :
1. Select trim command
2. Click on the limiting line
How to Use Explode Command
mancad
Explode command is a very useful tool to design in Librecad,
1. Block the object
2. Select explode comand
How to Create a Block - Librecad Tutorial
mancad
1. Draw your entity
2. From the menu select Block Create Block
3. Select your entity that will make up the block
4. Once the entity have been selected press the ENTER key
5. Specify the reference point of the block
6. The reference point is the base of the object when it is inserted
7. Write a unique name for the new block
12
