		I'm interested in using this program for geometric construction / exploration.
				What I need is for the 'distance point to point' tool to produce at least 8 numbers to the right of the decimal point. Is this currently possible? Also, is there a way to access this tool via the command line? Thank you! :-]  |
		The distance (point - point) is not using existing unit/precision framework.
				I am going to fix this, so the distance is by precision set in "Edit->Current Drawing Preferences->Units"
		I appreciate the prompt reply!
				Your dedication to this project is encouraging.
		fixed by commit: https://github.com/LibreCAD/LibreCAD/commit/2e6aa9fb4735be545bccccad7a561f4c58fdb53c
				in the current git HEAD, all actions under main menu "Info" should be using "Edit->Current Drawing Preferences->Units" precision and formats. Now for "point to point", it could read like: Distance: 114.01754251 Cartesian: (70.00000000 , 90.00000000), Polar: (114.01754251<52° 7' 30.059" )  |
		Thank you! I have downloaded Qt and unzipped boost (C:\boost\boost_1_57_0).
				When I load Qt Creator and try to open librecad.pro it says: Could not find qmake configuration file default. Error while parsing file C:/1B/LibreCAD-2e6aa9fb4735be545bccccad7a561f4c58fdb53c/librecad.pro. Giving up.  |
		I needed to configure the project.
				New problem: Can not find Boost installation in /boost/boost_1_53_0 I'm using windows 7, btw.  |
		Sigh... I think I need to compile boost or something?
				Running bootstrap gives: 'cl' is not recognized as an internal or external command, operable program or batch file. Failed to build Boost.Build engine. --- My research indicates I might need visual studio for cl.exe. I think installing an 11gb program is above and beyond what I'm willing to do to get this compiled. I'll wait for the next .exe release of LibreCad.  |
		you can follow our wiki for win32 building.
				http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_LibreCAD_2.0_on_Windows you will need boost, nsis, git, and qt, but you dont have to build boost. also, it is easier in linux or osx
		I already downloaded Qt (5.4) with the online installer... does it matter?
				I downloaded boost 1_53 and updated custom.pro I unchecked shadow build. I could not find this in Qt 5.4: "Select librecad as building target in Qt Creator (instead of tff2lff, which is another choice)" With build configuration set to 'release', I tried once with 'build project librecad' and once with 'build all' with I think the same result each time:
		Please follow the instructions for command line, instead of qt-creator:
				http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_Windows_by_command_line
		The last problem was because I ran cmd.exe instead of "Qt 5.4 for desktop".
		The clouds parted and a voice said "let there be an installer...".
				![]() Thanks guys!  |
		Just FYI, these appeared at the end of the build:
				--- Is there a command line command for the distance (point to point) tool?  |
		 !include: could not find: "custom.nsh" (nsis-5.4.nsi:6)
				is explained by the fact I never created that file ;-]. It's really a miracle it compiled the last time. I just found out today I needed to: press windows-key type qt open 'QT 5.4 for desktop' instead of opening the command line normally. The last time it worked only because I had used QT creator to build beforehand. Considering that part failed with errors, I say it was a miracle... ;-]  |
		we just merged a new feature designed by developer dinkel(Christian Luginbühl). This new feature requires libxml++ to build.
				Need some help to get LibreCAD to build in win32, after this merge.
		I just modified the rs_vector file for the ellipse tool fix,
				so I got around that. ;D What kind of help? Writting c++?  |
		no. Just to figure out how to compile it with libxml++, similar way to what we described for boost and muparser in:
				http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_LibreCAD_2.0_on_Windows  |
		Need to create a "linux building" article in wiki. Update dependency to include libxml++
