distance point to point precision
29 messages Options
12
I'm interested in using this program for geometric construction / exploration.
What I need is for the 'distance point to point' tool to produce at least 8 numbers
to the right of the decimal point. Is this currently possible?
Also, is there a way to access this tool via the command line?
Thank you! :-]
Re: distance point to point precision
The distance (point - point) is not using existing unit/precision framework.
I am going to fix this, so the distance is by precision set in "Edit->Current Drawing Preferences->Units"
Thank you! :-]
I appreciate the prompt reply!
Your dedication to this project is encouraging.
fixed by commit: https://github.com/LibreCAD/LibreCAD/commit/2e6aa9fb4735be545bccccad7a561f4c58fdb53c
in the current git HEAD, all actions under main menu "Info" should be using "Edit->Current Drawing Preferences->Units" precision and formats.
Now for "point to point", it could read like:
Distance: 114.01754251 Cartesian: (70.00000000 , 90.00000000), Polar: (114.01754251<52° 7' 30.059" )
Thank you! I have downloaded Qt and unzipped boost (C:\boost\boost_1_57_0).
When I load Qt Creator and try to open librecad.pro it says:
Could not find qmake configuration file default.
Error while parsing file C:/1B/LibreCAD-2e6aa9fb4735be545bccccad7a561f4c58fdb53c/librecad.pro. Giving up.
I needed to configure the project.
New problem:
Can not find Boost installation in /boost/boost_1_53_0
I'm using windows 7, btw.
Sigh... I think I need to compile boost or something?
Running bootstrap gives:
'cl' is not recognized as an internal or external command,
operable program or batch file.
Failed to build Boost.Build engine.
My research indicates I might need visual studio for cl.exe.
I think installing an 11gb program is above and beyond what I'm willing to do to get this compiled.
I'll wait for the next .exe release of LibreCad.
you can follow our wiki for win32 building.
http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_LibreCAD_2.0_on_Windows
you will need boost, nsis, git, and qt, but you dont have to build boost.
also, it is easier in linux or osx
I already downloaded Qt (5.4) with the online installer... does it matter?
I downloaded boost 1_53 and updated custom.pro
I unchecked shadow build.
I could not find this in Qt 5.4:
"Select librecad as building target in Qt Creator (instead of tff2lff, which is another choice)"
With build configuration set to 'release',
I tried once with 'build project librecad' and once with 'build all'
with I think the same result each time:
../../generated/plugin/plotequation/obj/plot.o: In function `ZN4plot8execCommEP18Document_InterfaceP7QWidget7QString':
C:\1B\libcad\plugins\plotequation/plot.cpp:60: undefined reference to `mu::Parser::Parser()'
C:\1B\libcad\plugins\plotequation/plot.cpp:61: undefined reference to `mu::ParserBase::DefineConst(std::string const&, double)'
C:\1B\libcad\plugins\plotequation/plot.cpp:62: undefined reference to `mu::ParserBase::DefineConst(std::string const&, double)'
C:\1B\libcad\plugins\plotequation/plot.cpp:63: undefined reference to `mu::ParserBase::DefineVar(std::string const&, double*)'
C:\1B\libcad\plugins\plotequation/plot.cpp:64: undefined reference to `mu::ParserBase::DefineVar(std::string const&, double*)'
C:\1B\libcad\plugins\plotequation/plot.cpp:65: undefined reference to `mu::ParserBase::SetExpr(std::string const&)'
C:\1B\libcad\plugins\plotequation/plot.cpp:66: undefined reference to `mu::ParserBase::Eval() const'
C:\1B\libcad\plugins\plotequation/plot.cpp:68: undefined reference to `mu::ParserBase::SetExpr(std::string const&)'
C:\1B\libcad\plugins\plotequation/plot.cpp:69: undefined reference to `mu::ParserBase::Eval() const'
C:\1B\libcad\plugins\plotequation/plot.cpp:71: undefined reference to `mu::ParserBase::SetExpr(std::string const&)'
C:\1B\libcad\plugins\plotequation/plot.cpp:76: undefined reference to `mu::ParserBase::Eval() const'
C:\1B\libcad\plugins\plotequation/plot.cpp:81: undefined reference to `mu::ParserBase::SetExpr(std::string const&)'
C:\1B\libcad\plugins\plotequation/plot.cpp:85: undefined reference to `mu::ParserBase::Eval() const'
../../generated/plugin/plotequation/obj/plot.o: In function `~Parser':
C:\1B\libcad\plugins\plotequation/../../libraries/muparser/include/muParser.h:57: undefined reference to `vtable for mu::Parser'
C:\1B\libcad\plugins\plotequation/../../libraries/muparser/include/muParser.h:57: undefined reference to `mu::ParserBase::~ParserBase()'
C:\1B\libcad\plugins\plotequation/plot.cpp:91: undefined reference to `mu::ParserError::GetMsg() const'
collect2.exe: error: ld returned 1 exit status
Makefile.Release:84: recipe for target 'release\plotequation1.dll' failed
mingw32-make[3]: Leaving directory 'C:/1B/libcad/plugins/plotequation'
Makefile:34: recipe for target 'release' failed
mingw32-make[2]: Leaving directory 'C:/1B/libcad/plugins/plotequation'
Makefile:194: recipe for target 'sub-plotequation-make_first' failed
mingw32-make[1]: Leaving directory 'C:/1B/libcad/plugins'
makefile:127: recipe for target 'sub-plugins-make_first-ordered' failed
mingw32-make[3]: *** [release\plotequation1.dll] Error 1
mingw32-make[2]: *** [release] Error 2
mingw32-make[1]: *** [sub-plotequation-make_first] Error 2
mingw32-make: *** [sub-plugins-make_first-ordered] Error 2
12:52:06: The process "C:\Qt\Tools\mingw491_32\bin\mingw32-make.exe" exited with code 2.
Error while building/deploying project librecad (kit: Desktop Qt 5.4.1 MinGW 32bit)
When executing step "Make"
12:52:06: Elapsed time: 27:30.
Please follow the instructions for command line, instead of qt-creator:
http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_Windows_by_command_line
C:\1B\libcad\scripts>build-windows.bat
C:\1B\libcad\scripts>call set-windows-env.bat
C:\1B\libcad\scripts>pushd ..
C:\1B\libcad>qmake.exe librecad.pro -r -spec win32-g++
'qmake.exe' is not recognized as an internal or external command,
C:\1B\libcad>if not _ == _NoClean (mingw32-make.exe clean )
'mingw32-make.exe' is not recognized as an internal or external command,
C:\1B\libcad>mingw32-make.exe -j4
C:\1B\libcad>if NOT exist windows\LibreCAD.exe (
echo "Building windows\LibreCAD.exe failed!"
 exit /b /1
The last problem was because I ran cmd.exe instead of "Qt 5.4 for desktop".
The clouds parted and a voice said "let there be an installer...".
Thanks guys!
Just FYI, these appeared at the end of the build:
2 warnings:
  !include: could not find: "custom.nsh" (nsis-5.4.nsi:6)
  File: "C:\Qt\Qt5.4.0\5.4\mingw491_32\translations\qt*.qm" -> no files found. (nsis-5.4.nsi:122)
Is there a command line command for the distance (point to point) tool?
is explained by the fact I never created that file ;-].
It's really a miracle it compiled the last time.
I just found out today I needed to:
press windows-key
type qt
open 'QT 5.4 for desktop'
instead of opening the command line normally.
The last time it worked only because I had used QT creator to build beforehand.
Considering that part failed with errors, I say it was a miracle... ;-]
we just merged a new feature designed by developer dinkel(Christian Luginbühl). This new feature requires libxml++ to build.
Need some help to get LibreCAD to build in win32, after this merge.
press windows-key
type qt
I just modified the rs_vector file for the ellipse tool fix,
so I got around that. ;D
What kind of help? Writting c++?
no. Just to figure out how to compile it with libxml++, similar way to what we described for boost and muparser in:
Need to create a "linux building" article in wiki. Update dependency to include libxml++
12
