librecad crashes when I try to open a file.
gelterfinger
Librecad crashes when I am trying to open a dxf file. I am using librecad 2.0.0beta1Compiled on: Jan 3 y2013 and Ubuntu 12.04. There are a few files that will open and work properly when opened. Most of them will not. when I click on the file the program immediately closes. From the "home" folder I can open the drawings folder and from there I can open all the dxf files.
I think that the problem started after an Ubuntu software update ( I am not 100% sure). At that time I had the Librecad version running that came with Ubuntu 12.04.
Re: librecad crashes when I try to open a file.
sp1der
If you are still having problems with this, can you attach a file for testing.
gelterfinger
Yes I still have the same problem, I have not tried to fix it recently as I was busy with other things.
I have attached a file from my drawings Library.
Gelterfinger
http://forum.librecad.org/librecad-crashes-when-I-try-to-open-a-file-tp5707439p5707541.html
To unsubscribe from librecad crashes when I try to open a file., click here.
Kitchen elev.dxf (233K) Download Attachment
your file opens perfectly in LibreCAD (windows) with latest code. I'll try later with other systems
in 2013-jan-31 are solved a crash with some dimensions, please update your LC and retest
I made more test with your file
OpenSuse 12.2 x86_64 with last code => works
lubuntu 12.10 x86_64 with 2.0.0beta1 2012-12-31 => works
lubuntu 12.10 x86_64 with all updates and 2.0.0beta1 2013-02-05 => works
A test that you can do is run Librecad from the console:
home@home> librecad --debug 2> lc.log
and attach the resulting lc.log file
