no node adding possible
glanzel
if i try to add a node to a polyline first
-> specify polyline to add node
appears. if i click to a polyline
-> specify adding node's point
come up, but nothing happens if i click to the point
where the node should be added
why.
lg grischan
Re: no node adding possible
When -> "specify adding node's point" message appears
Activate "snap on entity" and click to the point (pertaining to the polyline) where the node should be added.
On end, select the polyline without command, click and drag the node to move to another position
sp1der
In reply to this post by glanzel
Hello glanzel
1. Make sure the polyline is selected first (highlighted).
2. Make sure  you are snapping to the polyline.
Hope this helps.
glanzel
snapping to the polyline was the trick
thanks to both of you - grischan
