open a dwg file
7 messages Options
open a dwg file
Vincent FAVRE
hello,
I have just downloaded the software and tried to open a dwg file from an autocad source.
But libreCAD does not want to open my file: it says "experimental, save your work first. Continue?"
And then, after I have accepted, it returns to me "can not open the file; please check its existence and permission".
Someone could help me?
Re: open a dwg file
fa201
Did you installed the last 2.2.rc2 version ? The support of DWG format was recenlty improved.
You can check the Help/About menu.
Fabrice
Re: open a dwg file
Vincent FAVRE
Do you speak french?
Where do you get this last version?
I downlaoded the Version : 2.1.3
Compiler: GNU GCC 4.9.1
Compilé sur : Sep 23 2016
Qt Version: 5.4.1
Boost Version: 1.60.0
System: Windows
I dont think that it is the last one.
Re: open a dwg file
fa201
Yes I am French. For the benefit of all, we prefer to use English in the forum.
you version is the last official release which is quite old. I suggest to install the last not yet official release but it is stable. You can get the last version for Windows 10 at https://sourceforge.net/projects/librecad/files/Windows/NightlyBuilds/master/
Check the last date for the install program.
Fabrice
Re: open a dwg file
Vincent FAVRE
OK I understand.
I downloaded as you said the Version : 2.2.0-rc2-7-gc819fed7
Compilateur : GNU GCC 7.3.0
Compilé le : Mar 15 2021
Version de Qt : 5.12.4
Version de Boost : 1.65.1
Système: Windows 10 (10.0)
The same eror message appears first: "experimental, please save your work first, continue?"
And then after ok, the screen is black, but on the right side it is listed  a number of "sheets" like door, concrete, wood, ...
Do I have to do something to make the drawing appear?
Re: open a dwg file
Vincent FAVRE
In reply to this post by fa201
Hello again.
As a matter of fact, I had only to zoom the screen up to make my drawing appear.
I am now going to try to understand the software.
Re: open a dwg file
fa201
I suggest the wiki as a start and the user manual after.
Note that you can find Youtube video tutorials and some are in French.
Fabrice
