problem exporting texts
4 messages Options Options
toninotoner
hi
first thank for your time and your jobs
so... i'm trying to create some 35x10mm boxes with text inside. everything is ok in librecad but when i open the same dxf file with pycam or others cam programs no text appear, only boxes or other designs are ok. Why?
i tried to explode text in singles characteres but zero results... any ideas? thanks
Re: problem exporting texts
krzych
I don' t know what problem you have, but you can explode letters into primitive entities (lines, arcs, etc).
Select letters and simply choose explode from Modification menu.
In reply to this post by toninotoner
You do not give much information.
My test:
LibreCAD 2.0.0beta1 + latest code in OpenSuse 12.2 x86_64, pycam-0.5.1
Draw created with LC Hello word are MTEXT, Text word are TEXT, the rest 8 lines, saved as dxf12 & dxf2007
Attached sceenshot:
Bottom. original draw in LibreCAD
Top left. file saved as dxf12 and opened with pycam-0.5.1
Top right. file saved as dxf2007 and opened with pycam-0.5.1
Result: All is ok
toninotoner
This post was updated on Feb 26, 2013; 6:54pm.
In reply to this post by krzych
hi krzych, if I try to explode letters they become not made of a single line but many small ones.
example letter "L" appear like a vertical line and an horizontal one, when i need to mill it the machine made up/down twice. sorry for my english...
Hi Rallaz, i use xubuntu 12.04 - kernel 3.2.0.36 - pycam 0.5.1 - librecad 2.0.0beta1
pycam convert everithing but text. it has problems looking for text libraries.
the problem in not only in pycam but also in other CAM programs i use in windows
