operating layer not highlighted
24 messages Options
12
claus82
Hello, 3
I was asked to test, so I'm trying to contribute, this is my question
when you are operating on a layer, I remember that the layer in which you are operating should be highlited in grey (I mean in the layer list), did developers removed this or it's jues a bug?
in the image down here there is the version that I use is the one that I was asked to test
Re: operating layer not highlighted
In my linux system current layer are highlighted, may be Qt/windows bug?
Note: your version do not save dimension text style, update to LibreCAD-Installer-2.0.7-407-gffb7c2b.exe
claus82
I don't know Rallaz, in the PC where I've taken the pictures runs under W7 64bit.
Thanks for the advice!
Cla
Mike Hayes
Hi Claus
I've noticed the same thing. It's not a bug.
If you look carefully at your screen from a wide angle you will see the highlighting is actually there. It's just very feint.
It depends on whatever colour scheme you currently have set for Windows itself.
Mike
I just changed it to PaleGreen (commit).
Thoughts?
We can use hex codes. http://www.quackit.com/css/css_color_codes.cfm
Would something more pale be desirable?
#CCFFCC
claus82
Hi guys,
Rallaz, from my pc the highlighting worked and it was the xxxxxxx399 version, I'm downloading the 410, I guess I will have to install this version in my job station too.
Thanks to all, friends.
Cla
sp1der
#CCFFCC
To me this is great.
By the way any chance of adding in the proper colors in the 'Application' preferences instead of  just numbers?
Yes. You can currently type in anything from that link.
You can suggest some defaults if you want.
sp1der
No I was asking if there could be default 'true colours' added showing the colour - not just numbers. I know I can type any numbers,l'm not asking about that.
claus82
Thanks guys! Do you think you can do the same for the block list? (I mean having the green highlighted block)
Moreover, in order to empower the potetntial to LC, it would save a lot of time if it could be possible to have multiple selection for layers and blocks, with a "select all"/ "deselect all" option too.
What do you think? But I think this is a feature request.
I can give you immediately an example of the help that it would give this feature:
today I had to open a file with a lot of blocks, (believe me, they were really too many) and activate several layers to clean up that draw. I'm pretty sure that I'm not the only one having this kind of problems, especially if here there is someone that has to do with "proprietary" files.
Any opinion/suggest welcome
In reply to this post by sp1der
sp1der, I meant that you can type in any word from that link such as "PaleGreen",
and that adding words as defaults is possible. There is also QColorDialog, which I might try to implement.
We are probably going to make an option,
so that users can choose the selection color for all these cases.
quod erat demonstrandum
claus82
Very good!
Cla
sp1der
Okay thanks for the explanation.
Yes this would be a big improvement if you have the time to do it, thanks very much ravas for your effort for LibreCAD, its people like you that are going to make LibreCAD the best open source program for CAD.
I implemented the QColorDialog for the existing color options,
and added an assortment of named colors to the default drop down list.
One thing to note is that if the current color is black,
you need to adjust the vertical slider on the right
before the area to its left works as expected.
Adding the layer / block selection color option is next.
I'm thinking it might be useful to have a hotkey for the preference window.
Any thoughts?
sp1der
Hey, just seen this, this is much better, thanks very much.
Nice, I'm looking forward to it, its these little changes that make using the program all that much better for the end user.
sp1der
This is working in Windows just fine but not with Ubuntu, even after updating/upgrading?
12
