some questions about fireup for leaning LibreCAD
9 messages Options
Johnson
From the site, I just the method to fetch/build LibreCAD by ubuntu.
Does someone know how to get the code/ build LibreCAD and redhat linux ?
By the way, how to get "git" seriels command worked ?
Thanks for your help. I think I might be an expert with your help :)
Re: some questions about fireup for leaning LibreCAD
Johnson
yes
wingame82
Date: 2012-11-20 09:14
Subject: some questions about fireup for leaning LibreCAD
http://forum.librecad.org/some-questions-about-fireup-for-leaning-LibreCAD-tp5707240.html
In reply to this post by Johnson
Re: Re: some questions about fireup for leaning LibreCAD
Johnson
Hi, Ries
Thanks for your quick bring-up. I will catch hold of Rallaz if I saw him online.
Sorry for the typo. I mean how to install Git on Linux.... I am sorry I am really a beginner for Linux.
Thanks.
wingame82
Date: 2012-11-20 09:33
Subject: Re: some questions about fireup for leaning LibreCAD
Hey,
in reality it just's a couple of dependencies you need to meet. The dependencies can be found in the Ubuntu apt-get commands.
I believe redhat works with yum, or up2date and I believe most packages should be in there respected repositories.
If anything fails, see if you can reach-out to Rallaz. he lurks on this mailing list as well as on the IRC channel.
What di you mean with  ["git" seriels command worked] ?
Ries
http://forum.librecad.org/some-questions-about-fireup-for-leaning-LibreCAD-tp5707240p5707242.html
To unsubscribe from some questions about fireup for leaning LibreCAD, click here.
Johnson
Thanks very much . Let me have a try :)
wingame82
Date: 2012-11-20 10:20
Hey,
If you use a version of redhat you will properly have yum install,
then you can install git with : yum install git
yum search <name> allows you to search for packages (without < and >)
The cmd get's a bit used to, but once you have some basics, it's really easy.
I am pretty sure there are GUI tools for redhat aswell, I just never used them
so I cannot help you there.
On Nov 19, 2012, at 9:08 PM, wuxinjiang [via LibreCAD] wrote:
Hi, Ries
Thanks.
wingame82
From: <a href="x-msg://879/user/SendEmail.jtp?type=node&amp;node=5707243&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email]
To: <a href="x-msg://879/user/SendEmail.jtp?type=node&amp;node=5707243&amp;i=1" target="_top" rel="nofollow" link="external">[hidden email]
Hey,
Ries
To start a new topic under LibreCAD-dev, email <a href="x-msg://879/user/SendEmail.jtp?type=node&amp;node=5707242&amp;i=0" rel="nofollow" target="_top" link="external">[hidden email]
To unsubscribe from LibreCAD, <a href="x-msg://879/" rel="nofollow" target="_top" link="external">click here.
To start a new topic under LibreCAD-dev, email <a href="x-msg://879/user/SendEmail.jtp?type=node&amp;node=5707243&amp;i=2" target="_top" rel="nofollow" link="external">[hidden email]
To unsubscribe from some questions about fireup for leaning LibreCAD, <a href="x-msg://879/" target="_top" rel="nofollow" link="external">click here.
http://forum.librecad.org/some-questions-about-fireup-for-leaning-LibreCAD-tp5707240p5707243.html
http://forum.librecad.org/some-questions-about-fireup-for-leaning-LibreCAD-tp5707240p5707244.html
For rpm packages see:
https://github.com/Rallaz/LibreCAD/wiki/Rpm-packages
LibreCAD are packaged for RHEL 6, the src.rpm are in:
http://download.opensuse.org/repositories/home:/Rallaz/RedHat_RHEL-6/src/librecad-2.0.0beta1-1.1.src.rpm
Unpacked files:
https://build.opensuse.org/package/files?package=LibreCAD2&project=home%3ARallaz
This src.rpm require Qt4, of course, xz, muparser & libdxfrw
More info in this thread:
http://forum.librecad.org/Redhat-system-recompile-LibreCAD-tp5706714.html
Remember dxflib no more needed.
Cheers,
there's git support within qtcreator. install git and try to do git in qtcreator.
On Nov 19, 2012 9:20 PM, "R. van Twisk [via LibreCAD]" <[hidden email]> wrote:
Hey,
Hi, Ries
Thanks.
wingame82
Date: <a href="tel:2012-11-20%C2%A009" value="+12012112009" target="_blank">2012-11-20 09:33
Hey,
Ries
Johnson
Today I decide to use Ubuntu system to start the programming and learning.  All done. Thanks Rallaz anyway.
wingame82
Date: 2012-11-20 15:41
Subject: Re: Re: some questions about fireup for leaning LibreCAD
Unpacked files:
Cheers,
http://forum.librecad.org/some-questions-about-fireup-for-leaning-LibreCAD-tp5707240p5707246.html
